Wiper Problem!
Old Dec 1, 2006 | 10:08 AM
EB-Z06's Avatar
EB-Z06
Default Wiper Problem!
I have a little problem with the window wipers on the car.. They work perfectly fine when you power then on, but once you turn them off, they WILL NOT return back to their resting points tucked away behind the hood.. They stay up at the "idle" point as if they were still on (but they're really not, of course)
Anyone had this problem before? If its not an easy fix, I'll just let the GMPP take care of it!
Thanks!
Old Dec 1, 2006 | 10:55 AM
dpd's Avatar
dpd
park switch in motor is probably bad[needs new motor].check to see if the plenum is draining,if not the motor is probably under water.check the connector for corrosion.if all is ok,the motor is most likely bad
Old Dec 1, 2006 | 11:41 AM
GRAY BEARD's Avatar
GRAY BEARD
Had the same thing happen on my truck.
Old Dec 1, 2006 | 04:21 PM
EB-Z06's Avatar
EB-Z06
Good deal.. I'll just have the warranty replace it! Thanks!
Old Dec 2, 2006 | 12:26 PM
EB-Z06's Avatar
EB-Z06
Uh.. I turned the car on last night while at the Mall, and they returned "home"! Got to love American made..
To Wiper Problem!
