intake manifold upgrade?
Old Dec 4, 2006 | 08:05 AM
cruisemon's Avatar
cruisemon
Originally Posted by Iron Maiden Fan
This might help, it's a copy of an article from Corvette Fever, (Sept. 2004) that ran comparisions between FAST, LS1, LS6 with a stock engine, and with a cammed/header engine, on the dyno.
http://www.timelesscharms.net/ls1/co...on/compare.htm
I may have the magazine confused with another because the manifold test was just the LS1 and LS6 on a bone stock LS1. These and other tests in Corvette Fever bring to mind an amusing series of events maybe two years ago when CF announced a series of dyno tests of bolt on parts attached to actual cars driven by ordinary people on essentially bone stock engines. The first article dealt with after market air filters and bridges. A very heavily advertised air intake system showed negligible gains at start up and once the underhood temps warmed up, the power went down. Only by running the tests with the hood open to provide cooler air was there any advantage for the aftermarket system. Other intakes fared similarly with none delivering the tremendous improvements claimed. It was the ONLY article in the "series" that ever ran. Undoubtedly some of these products help but mostly I suspect many of them work mostly to sell advertising pages in the auto magazines.
Maybe the person posting who had the LS6 intake for sale and had dynoed it on his car will see this and tell us his story.
Charlie
Old Dec 4, 2006 | 10:06 AM
Face's Avatar
Face
While I just had bolt ons and a tune done(blackwing, TPIS LT's, Dr. Gas Offroad Pipe), I went went from the LS1 to LS6 intake. I only saw a 5 rwhp increase. I know others have seen more with similar mods, but you would be lucky to see over 10RWHP with your mods.
Old Dec 4, 2006 | 10:39 AM
cruisemon's Avatar
cruisemon
The post I referred to back upthread was in a PM from another member who was selling an LS6 manifold. He bought an engine that was supposed to have the LS6 and did not. The dyno number after swapping out the LS1 for the LS6 was less than 5 hp higher, even with a tune. I don't know how to reconcile this info with what others are seeing, except maybe the tuners that report the higher gains are better at tweaking the computer and fuel table than the dudes that don't.
Charlie
Old Dec 4, 2006 | 11:17 AM
DBLX's Avatar
DBLX
Default Is it, or is it not?
So much back and forth? Would this be a good mod to do on my LS1 with the TI exhaust and WCC X-pipe already installed? Or should I go with something else. Headers are in the very near future, as well.
DBLX
Old Dec 4, 2006 | 11:30 AM
kingsey's Avatar
kingsey
I already got the LT headers x pipe no cat borla stingers and a CAI was going to toss it on Would i get something at the wheels because my motor isnt bone stock?
Old Dec 4, 2006 | 02:23 PM
DBLX's Avatar
DBLX
bump
Old Dec 4, 2006 | 04:49 PM
MattB's Avatar
MattB
DBLX
Its hard to tell someone that its worth it. It does not give a lot of HP, and it costs $400 to $500 for the intake. You will either need to cut the bottom of the new intake to accomidate the stock coolant lines or get a bypass kit. Either will work.
I'm glad I did mine, I thought it had better trottle response and torque. This is my only engine mod so far, besides zip-tie. I'd do it again even if I wasn't planning on more mods. But, thats me
Old Dec 4, 2006 | 05:11 PM
jfrc's Avatar
jfrc
in the latest Vette mag, the ls6 made good power compared to ls2
should be able to get a good deal, or find one used
Old Dec 4, 2006 | 07:18 PM
Dan_the_C5_Man's Avatar
Dan_the_C5_Man
If you read through the article posted, the diff. between an LS1 and LS6 manifold is (at best with a cam installed) 6HP. Not so sure it's quite worth the dollars spent.
Seems like a better choice would be a used set of LS6 heads (and then maybe an LS6 manifold to compliment).
Old Dec 4, 2006 | 08:15 PM
cruisemon's Avatar
cruisemon
For the $350 manifold (used) plus a couple of coolant tubes plus maybe $40 for the gaskets plus the swap time, 5-6hp just ain't in the cards for me anymore.
If I were doing heads, headers, cam, etc., then the manifold and throttle body come into play. Otherwise, the LS6 manifold doesn't make sense, and this if from someone who was ready to pull the trigger on a purchase. If the person selling the LS6 manifold hadn't shot straight with me and told me the straight doo-doo about what the manifold did for him I would have bought that bad boy. Unless he gives me the go ahead, I can't say who that was because he may still be trying to sell the manifold. I'll tell you this, though. If a prospective buyer asks this guy the same questions I did, he'll give them the same answer because he is one STAND UP dude.
Charlie
Old Dec 6, 2006 | 01:20 AM
skelly1's Avatar
skelly1
Well said, gents. I'll probably just replace the sensor and be done with it.
Old Dec 6, 2006 | 02:15 AM
Showdown's Avatar
Showdown
good info.
Old Dec 6, 2006 | 02:21 AM
  #33
Showdown's Avatar
Showdown
Good Info
Old Dec 6, 2006 | 02:43 AM
  #34
LsJuan25's Avatar
LsJuan25
Im going withthe LS2 on my 408 really a (413 hehe) I did this because I can use the LS2 TB which I will get real gains from 78 to 90 mm. THey do have a LS6 with a 4 bolt pattern but to be honest the MAYBE extra 2 HP over the LS2 is not worth the extra 300 dollars plus tax the Ls6 intake cots over the LS2. Im talking about the Ls6 with the 4 bolt pattern for the 90 mm TB. I just got the Throttle body and LS2 intake with everything for the price of one 4 bolt Ls6 intake.
Old Dec 6, 2006 | 04:09 AM
  #35
Iron Maiden Fan's Avatar
Iron Maiden Fan
Charlie
That was my feelings. By the time you have enough mods to need a better flowing intake, your better off with a F.A.S.T. Compared to the cost of the mods it took to get there, it's a neglible difference over the LS6 intake. (my 2nd 2 cents worth... or 4 cents total )
Old Dec 6, 2006 | 10:13 AM
  #36
FrostyZ28's Avatar
FrostyZ28
Maybe Fbodys are different because I've seen a lot more than a 3-5hp gain on just a intake swap. I've also seen a few tenths at track just on the intake swap.
Like others have said it's more than just overall horsepower but to each their own.
Also, on a side note, a FAST intake is pointless on a stock motor, it's overkill, unless it's a FAST 78mm which at that point everyone will say screw the 78 and go with a 90.
Head over to LS1tech and see how a LS6 w/ported TB stacks up to a 90/90 on a stock headed and cammed motor, you'll be surprised
Old Dec 8, 2006 | 09:10 PM
  #37
vetterlatethannever's Avatar
vetterlatethannever
Charlie
:o
Old Dec 9, 2006 | 09:37 AM
  #38
cruisemon's Avatar
cruisemon
Originally Posted by vetterlatethannever
:o
Stand up dude has responded so I think it is okay to say the person who shot straight with me about this was Vetterlatethannever. If everyone selling on this forum had the same attitude and spirit there would never be a post about getting ripped off.
Charlie
Old Dec 9, 2006 | 11:54 PM
  #39
99torchredlb's Avatar
99torchredlb
If I upgrade my intake with FAST should I get the 90 or 78 throttle body? I have plenty of upgrades
