TCS Code 1217
Old Dec 2, 2006 | 01:35 PM
Y2KVTT's Avatar
Y2KVTT
Cruising
Default TCS Code 1217
I am getting this code that is disabling my ABS, traction control & active handling. It says the pump motor relay circuit is open. Does anyone have any info on this. I have a 2000 vert that drives me nuts when ths happens. Up here in the great white north, traction and handling is a must. Thanks
Old Dec 2, 2006 | 05:56 PM
ICUALL's Avatar
ICUALL
Default Fuse 53
1st thing to do is Check Fuse # 53 Underhood fuse center
Old Dec 2, 2006 | 07:14 PM
Y2KVTT's Avatar
Y2KVTT
Cruising
I'll give that a try. Thanks
Old Dec 2, 2006 | 08:27 PM
ICUALL's Avatar
ICUALL
Default Fuse 53
1st thing to do is Check Fuse # 52 & 53 Underhood fuse center. If both are good you need to clean the connections on the EBCM.
To TCS Code 1217
