Now I'm stumped...
Old Dec 2, 2006 | 01:44 PM
FletcherT76's Avatar
FletcherT76
Default Now I'm stumped...
So a while back both my fog lights stopped working for some reason. I just checked the fuse and no problem there. I went ahead and bought replacement bulbs even though the originals didn't appear to be blown on visual inspection. Re-connected the battery and still nothing. I reset all the codes on the computer and tried the lights, but still nothing. I'm at a loss at this point as to where my point of failure is.
Anyone got a clue?? I'm going without that extra light!!! I never thought they did that much until you start driving without them for a while.
Is it possible that the relay has gone bad? If so, how do I get it out because it doesn't seem to want to budge.
Thanks,
Trevor
Old Dec 2, 2006 | 02:10 PM
ALLEGRO's Avatar
ALLEGRO
Hummm.....
I would get a reliable volt/ohm meter and check voltage at the sockets, resistance across the fuse you think is good, voltage at the fuse slot and then......(hopefully not needed) pull the interior panel off and check the operation of the switch using the meter.
Good Luck
Old Dec 2, 2006 | 02:46 PM
2K2 C5's Avatar
2K2 C5
The switch pops out easily, check there for power first as it's upstream from the relay.
Old Dec 2, 2006 | 04:04 PM
FletcherT76
The light toggles off/on at the switch inside so I don't think that's the problem. I guess I'll have to get the voltmeter out and try to track down my point of failure.
Anyone have any other idea/suggestions?
T
Old Dec 2, 2006 | 07:40 PM
Last C5's Avatar
Last C5
T
Isn't there an electrical connection in front of the front fenderwells that is in weather and is sometimes the culprit?
Old Dec 2, 2006 | 08:29 PM
65GGvert's Avatar
65GGvert
Just a thought, don't they only come on when lights are on dim? If that's so, there must be a contact that turns them off when switching to bright. Maybe the multi-function switch or a relay between. I don't have a service manual, so I can't look it up for you.
Old Dec 2, 2006 | 09:02 PM
maestro300's Avatar
maestro300
I've got the same exact problem with my fog lights; if you find anything out let me know!
Old Dec 4, 2006 | 12:08 PM
FletcherT76
I haven't heard of this. Can anyone shed some light on what Last C5 is referring to?
Old Dec 4, 2006 | 03:52 PM
jashearer's Avatar
jashearer
The relay went out on my '00 coupe. Its a standard relay in the underhood relay box. They are pretty tough to pop out, but with some persuasion it will come out. I would check that first, much easier then tearing into other wiring...
Jay
Old Dec 4, 2006 | 05:12 PM
VetteTech81's Avatar
VetteTech81
try swaping the relay with another one and see if they work.... thats a real quick step... otherwise voltmeter or test light check power ground at the socket and work your way back to the source to isolate the problem.
good luck
-=Rick
Old Dec 4, 2006 | 06:28 PM
FletcherT76
Thanks guys! Is there a trick to removing the relay? I gave it a pretty good pull when I was first trying to diagnose the problem but it didn't want to give. I even tried to gently use a pair of plyers to get a better grip but still didn't seem like it was coming out, so I gave up not wanting to break it. I'm guessing it goes in just like a fuse - a couple prongs jammed in there??
I just remembered that when I had the hood up and pushed the fog light inside I could here a clicking sound from the fuse area. Is this indicative of a bad relay, or just normal functionality?
T
Old Dec 20, 2006 | 12:33 PM
FletcherT76
Default Still stumped...
Well my fog's still aren't working. I replaced both lights and all fuses just to be doubly sure that everything was correct there. I even stopped at the dealership yesterday to get some assistance on it. We pulled the relay out from the fuse box and put in a new one as a test; but the lights still don't work. I can here it click when I turn the fog light's on/off from the interior switch so I know there is power going to the fuse box.
I guess my question is how do I track down the point of failure from here? Anyone have a wiring diagram that would show where the wires go from the fuse box to the fog lights? What about the ground point - anyone know where that is so I could check there??
All other lights function properly, no codes in the DIC, and no other issues with the car besides this one thing.
Hope someone can help.
Trevor
Old Dec 20, 2006 | 12:46 PM
torchredfrc's Avatar
torchredfrc
How do your grounds (studs on the frame) near the hood struts look? You might try spraying some contact cleaner on them as I believe that's where the fog lights ground to.
Someone with the GM Service Manual DVD should be able to post a wiring diagram for your.
Old Dec 20, 2006 | 01:41 PM
BlackZ06's Avatar
BlackZ06
I don't have fog lamps, but the 2001 Service Manual wiring diagram shows:
Lamps are grounded at G102
They are powered by Purple wires (black is ground) that are powered directly off the FL Relay (#39) located in the Underhood fuse block.
Relay 39 is protected by fuse #6 (10 Amp) also in the underhood fuse block.
Power from the fuse also feeds the Fog Lamp indicator located with the fog lamp switch on the dashboard.
Weird as this may seem, the power source for the dashboard switch itself is from Fuse 32 (15 Amp) - Labeled Fuel Tank Door in the I/P fuse block. The power comes from that fuse, through the switch, and to the BCM.
HTH
Old Dec 20, 2006 | 01:53 PM
FletcherT76
Thanks for the info BlackZ06. Since I don't have it in front of me, let me see if I can get this straight:
Power flows from the battery > #6 fuse > #39 relay > fog lights via purple wires and grounded at G102. Is that correct?
Also, can you tell me where G102 is located?
Thanks again!
Trevor
Old Dec 20, 2006 | 02:03 PM
BlackZ06's Avatar
BlackZ06
Maybe this'll help make it clearer ....
When you push the button to turn ON the fog lamps, that completes a curcuit powered from Fuse 32 to the BCM.
When the BCM sees power on that wire, it closes two other circuits. One curcuit turns on the Fog Lamp Indicator in the dash once relay 39 closes, and the other curcuit sets Relay 39 to ON which then powers up the lamps and the indicator.
Since Relay 39 powers both the Indicator and the lamps, if your FLs aren't coming on, but the indicator light is ... then the problem is either in the relay itself or the wiring from the Fuse Block to the lamps (Purple wires).
I'd test the switch itself (Orange wire is power from Fuse 32 - Orange/Black wire goes to BCM) to see if that's working, check the BCM for DTCs indicating a FL problem, then if the BCM has no codes it is either the relay (39), the fuse (#6) or in the wiring harness from the Fuse Block.
HTH
Old Dec 20, 2006 | 02:06 PM
BlackZ06's Avatar
BlackZ06
Thanks again!
Trevor
Sorry, my description isn't clear ....
battery > #39 relay > #6 fuse > fog lights.
from #6 fuse to fog lights is purple wire, and then coming off the lamps are BLACK wires that are groundeed at G102. Let me find G102 and I'll post another reply in a couple of minutes
To Now I'm stumped...
Old Dec 20, 2006 | 02:10 PM
BlackZ06's Avatar
BlackZ06
G102 is on the top of the passenger side frame rail - in the engine compartment - forward most ground point, should be about even with the front of the wheel well (forward part of the wheel well liner).
Old Dec 20, 2006 | 03:44 PM
FletcherT76
Thanks for the info again BlackZ06. I'm looking around to see what I can come up with, but in the process found this little oddity on the drivers side. The pictures are drivers side, looking through the fog light housing (previous owner cut out the opening).
What is this connector? It's wires are a part of the grouping that comes over to the drivers side FL and has just been zip tied to the wiring harness:
A closer look:
Then I found this wire just comes out of the plastic sleeve and was just loose behind the body panel - any clue at all what this is!?
Old Dec 20, 2006 | 06:54 PM
red88L98convert's Avatar
red88L98convert
that's a vacuum line with a bolt in it....not a wire. unfortunatly, i don't know what the line is for...i'm sure someone else will know though.
