Now I'm stumped...
Old Dec 20, 2006 | 11:23 PM
ICUALL's Avatar
ICUALL
Default A.i.r Pump
Looks like someone has disabled the A.I.R. pump judging from your pics. The plug is located about where the A.I.R. pump is on the drivers side frame and the Vacuum Line Looks like the one which should be connected to it.
Fog lamp wiring
Last edited by ICUALL; Dec 20, 2006 at 11:41 PM. Reason: added link to wiring diagram
Old Dec 21, 2006 | 01:28 AM
Dan_the_C5_Man's Avatar
Dan_the_C5_Man
Yep, the connector and the plastic vacuum line previously serviced the A.I.R. injection pump.
Old Dec 21, 2006 | 01:57 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
There is a Splice Pack ground connection in the front facia for that connection. ALL of the front facia light grounds go to the Splice Pack
If you look at the back of the SP you will see a bunch of small wires and one big wire. The big wire combines all of the wires together via a ground buss bar and the wire goes to G-101 or G-102 behind the headlight doors on top of the frame:
G101
G-102
You will need to disassemble the ground connectors:
Clean and check the grounds.
BC
Old Dec 21, 2006 | 10:08 AM
FletcherT76's Avatar
FletcherT76
Thanks for all the info everyone! I'll take your advise and disassemble the ground pack and double check everything there.
What's the A.I.R. pump? Is it a problem that someone took it off mine!?
Old Dec 21, 2006 | 01:13 PM
FletcherT76
They work again!!!
I disassembled the ground pack per Bill's advice and cleaned the contact points. There were absolutely no signs of corrosion or bad contacts, so I just wiped them all down and re-assembled everything - VOILA! I can see again!
Thanks again everyone - you people are the best!
Trevor
Old Dec 21, 2006 | 01:52 PM
Dan_the_C5_Man
No, if it was de-installed properly (I used a large vacuum cap, slipped it over the end of the elbow, sealed with RTV vs. the bolt you have) then the owner did you a favor.. Have you had the car long enough for a smog check? As long as that passes and you don't have any A.I.R. system related codes, you are fine.
The A.I.R. system is designed to inject additional air into the exhaust upon initial start-up, forcing the cats to come up to temp more quickly. It only runs for about 30 seconds.
Old Dec 21, 2006 | 06:52 PM
FletcherT76
I've only had the car since September - but Indiana doesn't require inspections like most states so it isn't a problem and have never had any problems. Guess I won't worry about it.
