cam cost question
Labor - 1500 give or take
Cam= 300-400
Pushrods= about 200
Springs- not sure but could vary anywhere from 300-900 I would imagine depending..
then depending on what else you want with the cam, T-stat, timing chain?
Dyno tune will run you around 500 bucks at any decent tuner(like FLP) which you will have to get with a cam swap.
I would say over all 3- 4k is a safe number.
That should get you started.
Take LG Motorsports cam package for instance: You can get a G5X kit for about $1450 shipped. That comes with the cam, springs, pushrods, seals, seats, and retainers. You will need a basic cam swap gastket kit which runs about $50 from Texas Speed. A full case of Mobil 1 which can be around $75-$80. Two filters which is about $10. Then if you are going to have someone do it I will use Next Level Performance who quoted me around $900 for install and then $500 for the tune. So all in all you are looking at about $3000 give or take a few hundred. Hope this helps.
Is there a chance all the vendors would post their prices and packages by region so people can "shop" around? Sounds like ECS is already cool with it as well as CT Corvettes and I think I've seen Vette doctors in differnet threads post some packages as well.
, and a list of what is included, would making a decision a lot easier.
, I am offering free labor on the LT's w/ a H/C install
I think you need to know the exact parts being used to compare prices. As an example one tuner may use 918 springs while another is using 921 springs there is a significant price margin there.
I have seen too many posts where someone says my H/C cost only $xxxx and then after some reserach into what was done you see that different parts were used. this really does not make for a fair comparison.
ECS cam of choice.
Comp 921 Spring kit
titanium retainers
ASP under driver pulley
2 new belts
Roll Master double roller chain
New Crank bolt
Front main seal
Ported oil pump
Ported throttle body
NGK TR-5 plugs
Taylor wires
160 degree thermostat
Full Dyno tuning.
ECS cam of choice.
And all that, installed on a C5 costs...? $2995 w/918s?
I haven't done mine yet, but I'm gathering parts. Running the numbers, with a labor & tune quote from my guy of choice, comes out to around $3100. That's with typical XER cam, Patriot duals, quality pushrods, timing set, oil pump, ASP crank pulley, Katech tensioner, Synister PS pulley, belts, plugs, gaskets, thermostat, etc. Add another $100 or so for fluids, and maybe another $100 for shipping and stuff I forgot.
I am putting on a fairly extensive pulley package, and that adds almost $500 in parts, so you could do without that if on a budget. I figured spend the install money once, as all that stuff has to come off anyways.
Oh, and I may go with a two-piece front cover. A local guy has some in beta test and if that goes well I may add one. Figure another $200 or so.
Here's a breakdown. If I'm missing something, I hope someone more experienced will chime in.
Install cam & kit AV $750 Dyno tune AV $500 Cam TR $399 Spring kit Patriot $240 Pushrods Comp Forum $110 Timing set Cloyes SDPC $150 Oil pump LPE $100 Gasket kit GM SDPC $62 Spark plugs NGK TR $56 Balancer bolt ARP TSP $28 Underdrive pulley ASP Forum $210 A/C belt TSP $16 Accessory belt TSP $20 PS pulley SynisterTR $99 Oil pump HiVol LPE $100 Oil pump o-ring GM TR $5 Oil cooler gasket ? GM TR $4 Belt tensioner Katech $135 180 thermostat Hypertech Forum $40 PCV catch can NLP $90 $3,114
