Storage
Old Dec 5, 2006 | 09:07 PM
Pluto's Avatar
Pluto
Cruising
Default Storage
Should a 2004 that's being stored for the winter be started off and on? I do have a battery tender on it
Old Dec 5, 2006 | 09:32 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Add some sta-bil, fill the tank, run the car to mix the 2 gas tanks, use the battery tender.
You'll be all set for months.
Old Dec 6, 2006 | 06:00 AM
vettenuts's Avatar
vettenuts
I don't start mine at all and pull the battery and bring it in the basement. I put the car into a carbag to keep it dry since I live in an area that is very very damp.
Old Dec 6, 2006 | 08:19 AM
Pluto's Avatar
Pluto
Cruising
Thanks guys I did put stabil in the tank changed the oil and ran it for about 10 minutes I guess I'm alright
Old Dec 6, 2006 | 10:24 AM
Vetteoholic's Avatar
Vetteoholic
I keep Insurance on my Z all year. Even though It stays In the garage most of the Winter I will take her out for a quick ride If It's a nice rare 50* day and there Isn't much or any salt on the streets.
What I do Is top off all the fluids, change the oil/filter, Inflate the tires to 35 psi, detail It Inside/out plus the engine, Hook the battery tender up~put a thin towel on the fender Into the hood gap(So the cord Isn't touching my paint) close the hood but not clicking It shut. Then I put a nice car cover over her, set the garage heater to 67* & she's all good to go for the winter. Once a week I'll check on everything, & thats how I store my Z.
Old Dec 6, 2006 | 12:03 PM
rws.1's Avatar
rws.1
1. The issue with starting it and running it for a short period every so often is the water that is by product of the combustion process.
It leaves water in the oil and the exhaust sytem.... that leads to corrosion.
Even if you let it run 20 minutes and the engine is hot, as it cools, it will condense moisture out of surrounding air....
Metal + water = corrosion
2. cold starting induces the most wear, the fewer cold starts the better.
Letting it sit on a battery charger without running it, with a fuel stabilizer in a full tank is the best over winter storage advice.
Old Dec 6, 2006 | 12:08 PM
gdphillipsvette's Avatar
gdphillipsvette
Guys,
I don't want to hijack Pluto's thread, but what about when the car has to sit for 9 months?
I'm departing for Afghanistan for 9 months, home for two weeks, then back for another 6 months. Should I long term store it, or have the wife drive it occassionally?
Thanks, Gordon
Old Dec 6, 2006 | 12:47 PM
vettenuts's Avatar
vettenuts
Thanks, Gordon
Not sure, what is the bigger risk?
Just kidding. If you don't have the sand and salt issues we have, let your wife drive it occasionally. She will have to take it out often enough that the battery doesn't go dead though.
Old Dec 7, 2006 | 09:24 AM
Vetteoholic
Listen to this man
Old Dec 7, 2006 | 10:41 AM
Pluto's Avatar
Pluto
Cruising
Guys,
Thanks, Gordon
Be safe over there
Old Dec 7, 2006 | 10:53 AM
gdphillipsvette
Thanks Pluto!
Old Dec 7, 2006 | 11:40 AM
ytwokc5's Avatar
ytwokc5
The only argument I can make for starting occasionally in the winter is to run the A/C... keep those seals from drying out.
Old Dec 7, 2006 | 12:03 PM
Tigershark3's Avatar
Tigershark3
My .02 - Don't start it unless you're going to drive it up to operating temperture.
To Storage
