Bumper cross flags mounting?
Old Sep 26, 2001 | 12:25 AM
horsepit's Avatar
horsepit
Default Bumper cross flags mounting?
How is the cross flag mounted on the front bumper? Is it screwed or glued? Can I remove with out marks?
Old Sep 26, 2001 | 12:35 AM
intel55's Avatar
intel55
Default Re: Bumper cross flags mounting? (horsepit)
Well the rear is glued on so most likely the front is too.
:cheers: :flag
Old Sep 26, 2001 | 12:37 AM
joeflyer's Avatar
joeflyer
Default Re: Bumper cross flags mounting? (intel55)
If you remove the front emblem, you'll have two ugly holes to cover up. It's not glued on.
Old Sep 26, 2001 | 01:18 AM
horsepit's Avatar
horsepit
Default Re: Bumper cross flags mounting? (joeflyer)
Is it screwed on or can I pop it off and reinstall? I need to touch up a road chip next to it.
Old Sep 26, 2001 | 07:51 AM
97silverbullet's Avatar
97silverbullet
The front and rear C5 emblem is held on with 2 sided tape. The front emblem has 2 pegs on it for proper alignment, so there are 2 corresonding holes in the front cover. You can remove it with no problems, use a bonbo squeegee and hair dryer. Buy a new emblem to put back on. To reuse the old one, you will have to retape it. It is a PIA to retape. You will get better results replacing it. :chevy
To Bumper cross flags mounting?
