Ti muffler alignment
Old Dec 7, 2006 | 10:34 AM
imiuru's Avatar
imiuru
Default Ti muffler alignment
I just put on a Ti exhaust and the tips don't line up quite right. Just wondering how you adjust the exhaust. Do you just slide the muffler side to side in the hanger bracket?? seems like the only place to adjust, I did not see the if the bracket mounts move at all. Just got done late last night (did chassis plate as well) and wanted to get some input before I move forward.
thanks
Old Dec 7, 2006 | 10:40 AM
Casem1's Avatar
Casem1
thanks
You can shim the bracket mounts with washers. The bolts are fairly long giving you some room for play.
Is it a GM Ti exhaust? Mine lined up perfectly with no adjustment.
Old Dec 7, 2006 | 10:46 AM
imiuru's Avatar
imiuru
Yes it is GM Ti exhaust. I was thinking of washers also. Are the bolt holes slottled at all?? Could do a little bit there if it is. I know the mufflers slid in the wraparound bracket a little in shipping so it probably isn't right where it was when pulled off. They are close but are both still at \\ angles, Left side low and right side high.
Old Dec 7, 2006 | 10:48 AM
1999 Vette's Avatar
1999 Vette
Same on mine....I was told...there is not much you can do.
Old Dec 7, 2006 | 10:52 AM
Casem1's Avatar
Casem1
The holes are slotted, but unless you plug up the slot the bolts will 'creep' toward the center of the car over time. It is also hard to get a wrench on them if you want to tighten the bolt when it is directly above the exhaust pipe.
Just take your time an play. I saw a guy put several hours in a Borla catback (wow, they fit like a$$!!) He made some good progress but the passenger side just wouldn't line up.
Old Dec 7, 2006 | 11:02 AM
dwarmenzerk's Avatar
dwarmenzerk
actually there is something that you can do.. Take a piece of wood and put it between the mufflers and the top of the bumper..make sure its good and tight, align as you wish..
then tighten the bolts on the cat back..
Old Dec 7, 2006 | 11:04 AM
dwarmenzerk
i really hope he wasnt a professional, because we put my cat back on and aligned it, in less than 45mins.
Old Dec 7, 2006 | 12:18 PM
blazeone's Avatar
blazeone
For what it's worth I sold him the set. They lined up perfect on my car so it should just be a matter of fiddling with them. Good luck
Old Dec 7, 2006 | 03:17 PM
Sully1882's Avatar
Sully1882
Default ti exhaust
yeah you just need to loosen the two fastener bolts again and adjust the alignment. I was able to do mine in the driveway in just like 10 mins after the initial mounting... the Ti exhaust is great! Good luck...
Sully
Old Dec 7, 2006 | 04:24 PM
The Wrench's Avatar
The Wrench
I had one side low, the other high.
The only solution was to remove the bolts that attached to the mid-pipe and slot the holes with a dremel tool. Then they will twist a bit to raise/lower the tips into a parallel alignment. Those flanges must be Ti also, they were hard to slot with a dremel.
DG
Old Dec 7, 2006 | 04:49 PM
dudleyd's Avatar
dudleyd
Sully
I had the same problem when I installed my Ti's. Just loosen the two bolts in the catback flang, there is enough slop that you can rotate the catback slightly then tighten, you will probably need to tweek both to get them aligned with respect to one another.
Old Dec 7, 2006 | 08:46 PM
dwarmenzerk
it helps to have at least 2 people, one tightening/moving and one watching the alignment.
Old Dec 12, 2006 | 11:23 PM
imiuru's Avatar
imiuru
No worries for you my friend, I know it is just a matter of getting things just right. I got closer, but feel that the h-pipe needs to move in the right direction for everything to be ****. Still waiting for the time to do it. I thought about slotting the flange also, but will only do that as a last resort.
they do sound bitchen when your on it!!
Old Dec 12, 2006 | 11:34 PM
Vettman 1's Avatar
Vettman 1
I notice the horizontal rubber mount had two slots in it. One a bit higher than the other. I wasn't paying attention and slid one tang into the top slot on one side and the other was in the bottom slot. It's a 2K perhaps they've changed or modified the rubber mounting piece?
Old Dec 13, 2006 | 08:31 AM
Jstockton's Avatar
Jstockton
FedEx Bowl 4 St. Jude '09
St. Jude Donor '09-'10-'11-'12-'13-'14
I did the same thing... Check to make sure your "tang" is in the right spot... Did I say that out loud??
To Ti muffler alignment
