112lsa vs 114lsa
Old Dec 8, 2006 | 09:20 PM
Irish Whiskey's Avatar
Irish Whiskey
Default 112lsa vs 114lsa
with 224/228 cam in A4 with Yank SS3600 and headers what will be the daily drive difference between the two lsa's? 112lsa seems a little to rough 'at least in concept.
Old Dec 8, 2006 | 09:27 PM
zeevette's Avatar
zeevette
That's not a real radical cam, so the difference should be minor. It'll move your powerband down slightly, which is a benefit on an automatic with stall.
Old Dec 9, 2006 | 06:45 AM
lar66BB's Avatar
lar66BB
Default cam
The differance is idile, the 112 will be more choppy.
Old Dec 9, 2006 | 07:50 AM
JerriVette's Avatar
JerriVette
I'd go with the 114 lsa for civility and ease of tuning especially with the automatic...
Not to mention the 114lsa will still pass the tailpipe emissions testing should that come back into fashion in the future.
Good luck deciding.
Old Dec 9, 2006 | 08:21 AM
Gannet's Avatar
Gannet
St. Jude Donor '06
I'd go with the 112. Better DCR and a more street-friendly power peak. It's still short enough that the idle won't be too bad. But true, if you want a real smooth idle go 114 or more.
Old Dec 9, 2006 | 11:34 AM
99 vett babycar's Avatar
99 vett babycar
check out my sig for my specs-idles very smooth at 850, torque is flat from 2100 out to 5200 .Mods based on Tony Mamo's specs, 3years old and NO problems .
Old Dec 9, 2006 | 11:45 AM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
autos react differently to 112. I think you should stick with 114. Get 3.42s to make up the low end TQ.
Old Dec 9, 2006 | 01:58 PM
gettinthere's Avatar
0gettinthere
Former Vendor
I'd stick with the 114. It'll behave better on the street and be easier to tune. I swapped my car from an M6 to a built 4L60E and left the cam alone. The cam was on a 112 and there was a noticable difference.
Old Dec 14, 2006 | 02:09 PM
Cobra4B's Avatar
Cobra4B
CI 3-5-6-7-8 Veteran
I'm going through the same thing... G5-X2 112 or 114? Car is a '01 z06 w/ intake, kooks headers w/ cats and stingers.
Old Dec 14, 2006 | 03:35 PM
Alex1217's Avatar
Alex1217
When doing my heads & cam, I spoke to Chris and Doug at ECS extensively about what I wanted out of my heads and cam package. I have an A4 with stock 3.15 gears. They recommended a 224/230 cam with 114 lsa to both give me the numbers I wanted and to give me a comfortable idle and drive. You can still feel the lope at idle, I can imagine a 112 lsa would be even more pronounced. I would definitely go with a 114 lsa.
Old Dec 14, 2006 | 03:47 PM
black98c5's Avatar
black98c5
These days you can even run a 110lsa on a A4 DD car with a good tune......Its all in the tune
Old Dec 14, 2006 | 03:49 PM
Cobra4B's Avatar
Cobra4B
Going w/ 114.
To 112lsa vs 114lsa
