Shifter Question
Old Dec 12, 2006 | 04:16 PM
Z06Joe@AutoBuffs's Avatar
0Z06Joe@AutoBuffs
Former Vendor
St. Jude Donor '08-'09-'10
Default Shifter Question
I have done a search on the forum, but I am still a bit confused on which short throw shifter to purchase. I hear Hurst and the MTI 6 Shooter are the two. Please post more insight on just which ones and the pro's and con's. I know this is like but I just want to make this purchase only once. I do your basic driving, messing around and some track driving. Thanks in advance to those who reply to this thread.
Joe
Old Dec 12, 2006 | 04:48 PM
hattitude's Avatar
hattitude
If you go to the six-shooter web site they have a section that explains their shifter's pros and cons and I believe it compares it to the others available... It was good technical info..
Old Dec 12, 2006 | 07:39 PM
mark896's Avatar
mark896
I went with the C6 Z06 shifter.. Easy install, short throw, not too notchy... I love it. Bought it from Fred Beans.
Mark
Old Dec 12, 2006 | 10:00 PM
kevin40zx's Avatar
kevin40zx
I have the Hurst. Only bad thing about it is it rattles a little with the stock ****. Shifting from 2nd to 3rd has never been easier though.
Old Dec 12, 2006 | 10:48 PM
choirboy161's Avatar
choirboy161
Default shifter
B & M short throw shifter, nice and tight, easy shifts..
Old Dec 12, 2006 | 11:23 PM
mqqn's Avatar
mqqn
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Donor '03-'04-'05-'06-'07-'11
Hi Z06Joe -
The billet shifters will by nature transmit more noise into your passenger compartment - at higher rpms this can sound like a rattling from the shifter.
The shorter throw makes the shifts more positive (some would say clunkier).
The stock shifters are bushed with a rubber isolator to dampen the noise and make the shifting action smoother (I presume on the last part).
What I am trying to say is that the short throw billet shifters are not for everyone.
I love it at the drag strip, and driving around town. It would not be as much fun on a road course where I had to row it a lot, in that case I would probably want the improved shifter from a stock C6 Z06.
All that said, I think the best billet shifter out there is the Breathless Performance Products shifter.
This shifter is adjustable - you can vary the angle of the shift rod left, right, forward and back, and it has the option of an angled shaft or a straight one. IT's the only shifter I know of that has this ability to fine tune itself to your driving position.
Guess what, it is also probably the most expensive one too.
A lot of folks go with the B&M Ripper they are good with a good shift feel, but are not as adjustable.
best regards -
mqqn
Old Dec 13, 2006 | 07:45 AM
0Z06Joe@AutoBuffs
Former Vendor
Thanks for all your feed back, I knew this was going to be a difficult decision.
Old Dec 13, 2006 | 03:02 PM
ALLEGRO's Avatar
ALLEGRO
I chose to just shorten the OEM unit. Took off 1 inch and I like it. Really easy mod and it made a big difference in the action.
Old Dec 13, 2006 | 03:40 PM
02gt350's Avatar
02gt350
new B&M for C5 anf C6's.....love it. Couldnt be more perfect, plus its dead silent
Old Dec 13, 2006 | 08:40 PM
craig04c5's Avatar
craig04c5
I also went with the C6 shifter and love it. I specially like the feel of the C6 shift ****.
Old Dec 13, 2006 | 10:06 PM
lloaf's Avatar
lloaf
Another vote for the new B&M shifter. Really like its short throws , feel and silence. If the shaft was about half an inch shorter, it would be perfect.
Old Dec 13, 2006 | 11:40 PM
'VETTE PHASE's Avatar
'VETTE PHASE
Cruise-In VIII Veteran
Old Dec 14, 2006 | 02:53 PM
gorillavet's Avatar
gorillavet
I would strongly suggest you look at the six shooter web site. Not only does it tell you how this shifter was designed but it also addresses the myths about short stock shifters and C6 shifters. It is very informative and since you are trying to make a decision, why not check it out. You can find this at: www.mtiracing.com They are a forum sponsor.
To Shifter Question
