99 6 Spd With Code P1637 Codes
Old Dec 12, 2006 | 09:35 PM
TOPKATTKG2's Avatar
TOPKATTKG2
Default 99 6 Spd With Code P1637 Codes
Help!!!!!!, I Need Help Diagnosing A Code P1637, 99 6 Spd, Battery Goed Dead In 5-6 Days If Not Started And Driven, L Terminal On Alternator. Shows 13.5 Volts When Running, But At Times Only Shows 11.3 Volts, Looks Like Orig Alt On Car, Changed Batt With Known Good Unit. Found Small Bundle Of Wires Caught Under Battery, Between Batt And Batt Frame, But Did Not Yet Cut Open Harness To See If Wires Actually Cut Or Damaged, Wondering If This Small Bundle Of Wires Is Part Of L Terminal Going From Alt. To Pcm, Any Help Greatly Appreciated, Topkat.
Old Dec 12, 2006 | 09:55 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Takes 10 min to examine wires inside harness. Recommend removing the wires, examining each one nad repairing what ever damage you find.
BC
Old Dec 12, 2006 | 10:15 PM
TOPKATTKG2's Avatar
TOPKATTKG2
Default Thanks
Thanks For Quick Response To Question, Will Try Wiring Harness Inspection Asap, Topkat
To 99 6 Spd With Code P1637 Codes
