What should I pay for Sway bars???
Dec 15, 2006 | 04:28 PM
Quote:
Originally Posted by
Switchbarrel
The VB&P printed catalog lists both solid and new tubular ADDCO swaybars.
-Rick
Ok, well if they just came out with them, then I guess the CC ones are hollow. Does it happen to mention wall thickness?
Dec 15, 2006 | 04:37 PM
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
Dan_the_C5_Man
If you had a 2000 FRC, all you'd need is the front Z06 bar, but since you have a 99 you'd need both.
I started with stock (Z51), then Z06, now Hotchkis (bought them used).
Hotchkis is the solution, no question.
what about the rear on a 2000?
Dec 15, 2006 | 05:43 PM
Another vote for the hotchkiss, I have them, (tony the tiger voice) therrrrry're GREAT!
Dec 17, 2006 | 12:16 PM
OK...Hotchkis it is with a nice set of Bilstien Sports.
Thanks for all of your comments.
Dec 18, 2006 | 12:36 AM
Ikester
To be absoultely sure, I PM'd Gene Culley when he was still at Fred Beans; he looked up my VIN, responded that I did not need the rear. I'd provide you with the part number on the tag, but I sold them a while ago.
You could measure the O.D. of your bar, comapre it to a Z06 bar.
Dec 18, 2006 | 09:32 AM
CI 6-7-8-9 Veteran
Dan_the_C5_Man
good to know! Sounds like they are the same thing! Love this forum!
Dec 19, 2006 | 12:11 AM
St. Jude Donor '08
Autocross & Roadrace Forum Sponsor
ICaughtVetteFever
No, they are not as stiff as T1.
You are partly right. The front is a little softer, the rear is a little stiffer. The important part is that they are adjustable. Stiffness is nothing without balance.
Here is some actual info I posted in another thread.
http://forums.corvetteforum.com/show....php?t=1576827
-Aaron
Dec 19, 2006 | 09:04 AM
I have an '02 roadster. Any idea how much it should cost to have the Z06 bars put on mine? I mean labor costs. TAI
Dec 19, 2006 | 11:21 PM
Do it yourself, simple remove and reinstall procedure, and the best part is it will be FREE.
Dec 19, 2006 | 11:39 PM
If you're only driving on the street then the Z06 bars are the only way to go ...pointless getting anything else. IMHO.
