LQ9 heads on LS2 block. Will it work?
Old Dec 15, 2006 | 12:54 PM
YELLOHHH's Avatar
YELLOHHH
Default LQ9 heads on LS2 block. Will it work?
Old Dec 16, 2006 | 04:30 PM
Bink's Avatar
Bink
Cruise-In V Veteran
St. Jude Donor '09
Originally Posted by YELLOHHH
LS2 is 4" bore and LQ9 is 3.9". New L92 heads are a better fit.
Old Dec 16, 2006 | 07:57 PM
muncie21's Avatar
muncie21
317 heads are used on both LQ9 and LQ4 engines, both of which are 6.0L truck engines with 3.996" (101.5mm) bores.
LS1 has a bore of 3.898" (99mm)
LS2 has a bore size of 4" (101.6mm)
In my opinion the 317's on a LS2 are a good fit if you are FI and on a budget. 317's can use the stock intake.
Old Dec 16, 2006 | 08:58 PM
EG@EnglandGreen's Avatar
0EG@EnglandGreen
Supporting Tuner
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
LQ9's fit fine
Old Dec 17, 2006 | 08:08 AM
Cajundude's Avatar
Cajundude
Active Streak: 90 Days
Cruise-In 7-8-9-10 Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Originally Posted by EnglandGreen
LQ9's fit fine
I am running MTI 2R heads on my LS2 and they started with a 317 casting and chopped away.
Old Dec 17, 2006 | 11:45 AM
Stangkiller's Avatar
Stangkiller
CI 5-6-7-8-9-10 Veteran
St. Jude Donor '07-'08
Sure, that'd be nice, but there's no exhausts that fit the C5 yet.
Old Dec 17, 2006 | 12:06 PM
Y2Kvert4me's Avatar
Y2Kvert4me
St. Jude Donor '03
You'd better explain that one, as there are already C5's on the streets with the 402/L92 heads.
Old Dec 17, 2006 | 10:23 PM
YELLOHHH's Avatar
YELLOHHH
LQ9's fit fine
Exellent! Thanks Stephen.
Old Dec 17, 2006 | 10:27 PM
Phil97SVT's Avatar
Phil97SVT
Greg,
We're building an LS2 TTI Stage-X right now for sam's car, if you need a motor let me know. How's the insurance world going?
Phil
Old Dec 17, 2006 | 11:05 PM
YELLOHHH's Avatar
YELLOHHH
Originally Posted by Phil97SVT
Greg,
Phil
It's not. Back in the car business. I couldn't stay away! Just wanted to know if I pull the trigger on a LS2 402 shortblock, would I be able to re-use my current LQ9 heads. If you want to price me out the shortblock, shoot me a PM.
Old Dec 18, 2006 | 07:44 PM
FixedRoof's Avatar
FixedRoof
Cruise-In VI Veteran
Yeah right... Any LSx based header will bolt up to an L92 head. I have seen them in person.. There have been PLENTY of setups done.
BUT... since YELLOHHH has a Magnacharger they WONT fit. It won't bolt up to an L92 head. The Magnacharger (intake) uses stock LS1/LS2 style intake port configuration. The L92 is Different. His best bet is a 317 or aftermarket cylinder head or get a different supercharger.
Old Dec 19, 2006 | 11:54 AM
YELLOHHH's Avatar
YELLOHHH
Originally Posted by FixedRoof
BUT... since YELLOHHH has a Magnacharger they WONT fit. His best bet is a 317 or aftermarket cylinder head or get a different supercharger.
http://forums.corvetteforum.com/show....php?t=1573996
Old Dec 19, 2006 | 06:54 PM
Cobra4B's Avatar
Cobra4B
CI 3-5-6-7-8 Veteran
Cumdumpster... get a 416 w/ L92 heads and L76 intake w/ TTiX Then lemme roast some tires w/ it.
Old Dec 19, 2006 | 07:07 PM
YELLOHHH's Avatar
YELLOHHH
I'm on it...
Old Feb 7, 2007 | 09:25 PM
valdeztke's Avatar
valdeztke
Anyone know if Phil is still into building motors or is he "retiring"?
To LQ9 heads on LS2 block. Will it work?
