Headers installed, now car won't start
TIA- Mike
Is the MAF plugged in up in the Stinger setup?
Are the coils connected?
Is the motor on the driver's side of the throttle body disconnected?
Is the battery fully charged?
If all is OK, I think I might disconnect the battery for a few minutes and re-connect, but reduced engine power is safety related and it sounds like something is not connected properly.
read and post the DTC codes:
This is the absolute best C5 Diagnostic Trouble Code (DTC) web site!!!
http://www.corvettedoctor.com/Code_Main.html
http://www.corvettedoctor.com/index.html
Go to “technical data base” and then to “Corvette ECM Computer Codes”. Then select your year car. Read the instructions and then scroll down to the "READ MORE" window to view the code definitions.\
Here is another very good site:
http://www.obd-codes.com/trouble_cod...d-ii-codes.php
Make sure to include the H or C suffix!!
Write down and post your DTC’s Then clear them ALL!
Sound effects are cool too!
While your reading this, and trying to figure out whats wrong, charge the battery! Thats the first place to start. Then read and clear ALL of your DTC Codes. Then give her another try.
If that still fails the current set DTCs should tell us whats failing.
Did you disconnect any of the following :
Coil packs
Engine grounds
MAF
PM me if you neeed to
BC
Bill-
I checked the codes and and in each parameter it said NO COMM which I assume means everything is O.K. and after getting through them all said NO MORE CODES. When I installed the headers and intake I had the coils. MAF, starter, alternator, and grounds disconnected, but everything seems hooked back up properly. I had the battery disconnected while doing the work, and have had it on a float charger the past few day, so I think it should be charged.
Any more ideas would be great. I'll try disconnecting the battery for a while and see if that helps.
Thanks again- MIKE
NO COMS is B A D!!!! It means that the module is NOT commumicating with other modules. If you have all NO COMMS, you have a major electrical issue. Most likely grounded a serial buss. That's the buss that all the modules communicate on using serial digital data. BC
BC
The first is, you lost power to all the modules.
The second is, you lost grounds to the modules and the most likely is, you shorted a serial buss communication wire. If you short one,,,you effect then all.
The first thing that I would do is check ALL the wiring harnesses that you touched and even the ones that are around, under or beside anything that you moved.
To the left of the BCM, you will see two small weird looking connectors:
They are the serial buss.
As weird as it might sound,,,
try this:Shake the accordion tube that runs between the door and the door frame and then see if it will start!
The connector has a bad habbit of shorting.
Here is a prime example why:
BC
Bill-
Forgive my ignorance, but where exactly is the BCM. I am assuming it's the shiny component next to the fuse box in the picture, but I don't see anything like that on my car. Do I need to remove something to expose it. I also tried wiggling the door harness and that didn't work. Maybe if I let it sit over night it will cure itself
if nothing else hopefully my headache will go away.
Thanks for your time- Mike
How do you tell if the serial busses are shorted or not. The only wires that I could see being affected by the header install would be those going to the O2 sensors, the grounds, and the starter wires. Other than the grounds, would these other wires affect the BCM. I should also note that in the summer months the car was only a weekend driver, and often when I would insert the key it would not remember my seat memory. I would have to push the button on the door for it to adjust. Don't know if that is a sign of a problem or not. The car is still under warranty through Sept., but I'd like to know if this is header install related or something due to the car sitting with batt. disconnected etc.
Mike
check to see if that is plugged in. my car started right up after it was plugged in.
Love the sound of the new AR's.
It's -4 outside right now so I think it's going to be a while before it sees the road.
Thanks Bill and everyone else for taking the time to help me out. I appreciate it.
Mike
We got work to do!
