Oil pressure sender
Old Dec 16, 2006 | 08:43 PM
sugarwolf's Avatar
sugarwolf
Default Oil pressure sender
Ok what the hell is the deal with the bad oil pressure sending units. Mine said i had 129lbs of pressure so i order one from napa. I end up with a aluminum one and installed it and now says i have zero psi at idle and 12lbs full throttle. I know my engine has more oil pressure than that since it doesnt knock and i drive it liek i stole it. I do have a noise valve train after a z06 cam swap since i used stock pushrods. So i put the old sender back in since i get the low oil pressure dinging and dic light. So whats the best unit to buy.
Old Dec 16, 2006 | 09:06 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
I think many are replacing the OPS and not cleaning the oil out of the plug-which is often dripping wet
the Rockauto sensor was recently given the thumbs up, funny to see the GM part number on it(in a Standard box), about $35 shipped
Old Dec 17, 2006 | 10:29 AM
RichAshley-Black99's Avatar
RichAshley-Black99
I got one from O Riellys for $32 I believe it was a borg warner sensor Ive had it in for a few months with no Issues
To Oil pressure sender
