grease fittings
Dec 16, 2006 | 10:10 PM
grease fittings
Are there any grease fittings on the c-5?
Dec 16, 2006 | 10:27 PM
I have not found any...
Dec 16, 2006 | 11:35 PM
Cruise-In II Veteran
None that I know of... unless you add adjustable sway bar end links (like what comes with the Hotchkis sway bars). I now have 8 zerks to deal with.
Chuck
Dec 17, 2006 | 08:14 AM
Quote:
Originally Posted by
chuck1026
Chuck
What kind of grease do you use? Have you had any problems with squeeks from the Hotchkis? Thanks, Mark
Dec 17, 2006 | 09:22 AM
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I have greased my C5's by the use of a grease needle. You attach it to your grease gun, stick it in the rubber ball joint boot and inject until the boot has grease in it. You can get one at NAPA. There the biggest nastiest needle that you could ever imagine! They work well!!
BC
Dec 17, 2006 | 10:51 AM
VET IT B
I'll let you know in the spring... I just put them on the other day while my C5 is "under" for hibernation.
Dec 17, 2006 | 10:55 AM
Bill Curlee
BC
That is a cool idea for the "sealed boots".
Dec 19, 2006 | 07:54 AM
VET IT B
Anyone have grease suggestions?
