Header Install Question $$
Old Dec 19, 2006 | 03:14 AM
YomasterScott's Avatar
YomasterScott
Default Header Install Question $$
Hi all,
So I finally purchased my headers and hi flo cats. Went to a local C5/C6 specialist and he quoted me $500 for the install and another $525 for a dyno tune. Seems a little excessive to me, at least for the install. I think the dyno price is about right. What do you guys think? I will be using all of my own parts, but may require a little welding. Anyone know of a reputable shop here in Tampa?
Old Dec 19, 2006 | 06:36 AM
EdsC6Z06's Avatar
EdsC6Z06
St. Jude Donor '05-'06-'08-'10
You might want to wait on the tune if you're planning more mods. $500 doesn't seem that high to me. Headers can take quite a few hours to install.
Old Dec 19, 2006 | 06:59 AM
mph1972's Avatar
mph1972
Cruise-In VIII Veteran
St. Jude Donor '07
Why not DIY? Really it isn't a hard install if you take your time. Certainly would save a lot of money and I agree with the above statement, but to get the full gains out of a set of headers, a tune would be it.
Just a piece of advice, if you fill in your profile completely and let folks know where you are, there are some of us that like to help others install performance mods and such.
Good luck.
Micah
Old Dec 19, 2006 | 07:54 AM
oldschoolvette's Avatar
oldschoolvette
This install should take about 4-6 hrs depending on how well things go. If you do the math, thats around 100/hr. I would agree with MPH1972 why not do it yourself. I bet you could get some help if you asked.
Old Dec 19, 2006 | 07:56 AM
mph1972's Avatar
mph1972
St. Jude Donor '07
Check this website out...
http://www.ls1howto.com/
Old Dec 19, 2006 | 07:57 AM
oldschoolvette
Very good source of info
Old Dec 19, 2006 | 08:24 AM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
Originally Posted by YomasterScott
Hi all,
I'd suggest contacting Englandgreen
Old Dec 19, 2006 | 08:55 AM
Billdog350's Avatar
Billdog350
Welding? So you're keeping your stock H pipe and adapting the headers and cats to that? Why not spend the $500 you would have spent to have someone install and put that towards an X setup that will bolt to your headers, cats and catback? Welding stainless requires MIG/TIG and some decent welding ability....might as well get the right parts rather than hacking the install to save a few bucks and end up paying more to install.
I did my LG street setup and a friends (1997 and 2000 M6), each took about 7 hrs but that included the stupid AIR tube. Skip that part of the process and just block them if you have the AIR connectors on your headers and it should take a lot less.
Old Dec 19, 2006 | 09:45 AM
wayneinvirginia's Avatar
wayneinvirginia
I paid $600 for a Dynamaxx exhaust system install here in Virginia, the dyno tune cost me an additional $375.
Old Dec 19, 2006 | 10:40 AM
SteveDoten's Avatar
SteveDoten
I am surprised to see anything over $400 for the LT install
Old Dec 19, 2006 | 11:18 AM
Chuck01's Avatar
Chuck01
Old Dec 19, 2006 | 11:55 PM
Showdown's Avatar
Showdown
750 for header install. 200 for the x-pipe and hf cats. This is from a so called "CORVETTE SPECIALITY" shop near Riverside, CA. WTF!!!!
Old Dec 20, 2006 | 02:15 AM
YomasterScott
I already have a WCC x-pipe and B&B Tri Flo PRT cat back. The headers i bought from that auction site along with a set of 3" hi flow cats. I guess I wouldn't need any welding if I just clamp it all together. I would love to do the header install myself, I am somewhat mechanically inclined and I believe I could do it. Unfortunately, I don't have access to a lift and I wouldn't attempt it on jackstands. I would be willing to pay to use someones lift. If there are any kind souls in the Tampa area who would like to help me out, it would be greatly appreciated.
Old Dec 20, 2006 | 08:16 AM
KidCid's Avatar
KidCid
CI 7-8 Veteran
You guys obvoiusly don't live in the land of inflated prices. (i.e. Virginia).
Old Dec 20, 2006 | 08:31 AM
Billdog350's Avatar
Billdog350
I already have a WCC x-pipe and B&B Tri Flo PRT cat back. I would love to do the header install myself, I am somewhat mechanically inclined and I believe I could do it. Unfortunately, I don't have access to a lift and I wouldn't attempt it on jackstands.
We did both sets on jackstands. It really isn't too bad of a job if you drive the car up rhino ramps, then get a jack under there and go as high as the jack will go and then support it with jackstands...then jack the rear as high as that will go. Passenger side goes in from the top after removing the valve cover..so you only need to be under there to loosen the starter, remove a few ground wires, and install the drivers side...plus connect the pipes to cats, X and catback. I'd NEVER do a clutch without a lift but I think the headers are totally "driveway" doable.
Old Dec 20, 2006 | 09:30 AM
jfrc's Avatar
jfrc
DIY, get a buddy to help, pay him in beer and pizza
the money you saved will pay for the dyno tune
Old Dec 20, 2006 | 06:44 PM
nlreb54's Avatar
nlreb54
I did mine also myself in the garage with jackstands. No problem. Give it a shot.
To Header Install Question $$
