rear leaf spring removal ???
Old Dec 20, 2006 | 11:47 PM
pylant's Avatar
pylant
Default rear leaf spring removal ???
May have to remove the rear end and noticed in my shop manual that a special tool is used to compress the rear spring.
Is there another technique to remove the spring with out the tool??
tks
Old Dec 21, 2006 | 12:58 AM
Dan_the_C5_Man's Avatar
Dan_the_C5_Man
No special tools needed; simply support the car taking the weight off the rear wheels, undo / remove the adjustment bolts on either end, remove the center brackets.
Just be careful and use common sense, safety first.
Old Dec 21, 2006 | 04:11 AM
ICaughtVetteFever's Avatar
ICaughtVetteFever
About 15 min after car it up and wheels are off. I just did the job converting to coilovers.
Old Dec 21, 2006 | 06:19 PM
pylant's Avatar
pylant
Default Thanks for the feedback
Thanks guys.
Alot of things in life are not as hard as they may first appear.
To rear leaf spring removal ???
