Old Feb 20, 2015, 01:10 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Exterior How-Tos
Print Wikipost
jacking up 99 vette
Old Dec 21, 2006 | 06:44 AM
adf's Avatar
adf
Default jacking up 99 vette
I have to send my 4 wheels to the new buyer, therefore, I have to jack up my car and put it on jacks for a short time. Looking at the undercarriage it appears as though there is not any real good location to put my 4 jacks. Any suggestions please would be helpful. I have never done this before obviously.
Thanks,
Dean
Old Dec 21, 2006 | 07:06 AM
berryj's Avatar
berryj
Easiest way in your case is to place the jacks CAREFULLY under each jacking point on each side of the car. There are 4 points you'll see directly under the rocker panels which are just big enough to fit a jack. These each have a hole in the frame where a jacking puck would fit. However you can jack from these w/o one if u do it very carefully and actually watch where your jack is contacting. Make sure it is on the metal of the frame and avoid touching the thin fiberglass rocker panels otherwise you'll crack them!
I've done this and had wheels off w/o a problem.
Old Dec 21, 2006 | 03:11 PM
AnteVenom's Avatar
AnteVenom
Cruise-In IV Veteran
Daytona Jam 1 Veteran
I use the ends of each of the crossbars front and rear. Since I am lowered a bit I drive car onto four pairs of 2X4s, jack up the front via the crossbar, install two jack stands, adjust up their height, lower car onto jack stands in front, jack up the back, install jack stands at same relative height as front.
Good luck!
Old Dec 21, 2006 | 05:09 PM
Eddyd's Avatar
Eddyd
Good luck!
What he said.
Old Dec 21, 2006 | 08:12 PM
Tex_Vette's Avatar
Tex_Vette
Just Passin' Thru
I ran across this online article years ago:
http://www.idavette.net/hib/C5diy/c5diy1.htm
It was what prompted me to buy the Lincoln jack that Hib mentions and it is the way I have been jacking up my '99 ever since. Hope this helps...
Tex_Vette
Old Dec 21, 2006 | 10:16 PM
adf's Avatar
adf
Default jacks
Good luck!
thanks for the advise
Old Dec 21, 2006 | 10:17 PM
adf's Avatar
adf
Default jacks
Tex_Vette
thanks for you help. I will take a look
Old Dec 21, 2006 | 10:18 PM
adf's Avatar
adf
Default jacks
thanks for your help
Old Dec 22, 2006 | 12:22 AM
Mike98SilVert's Avatar
Mike98SilVert
Active Streak: 90 Days
I use the ends of each of the crossbars front and rear. I drive car onto four pairs of 2X4s, jack up the front via the crossbar, install two jack stands, adjust up their height, lower car onto jack stands in front, jack up the back, install jack stands at same relative height as front.
I use 2X12's
Some more links:
http://www.z06vette.com/diy_lift.php
http://www.97vette.com/howto/carlift/index.html
To jacking up 99 vette
