Question about MN6 Reverse Shifting
Old Dec 21, 2006 | 05:13 PM
ratman228's Avatar
ratman228
Default Question about MN6 Reverse Shifting
Hello,
I read in the Owners Manual that when parking on a hill that the car should be put in Reverse and not 1st gear as I have done with other manual cars. What I found is that it is very easy to pull to a stop, push the clutch in, shift into reverse and then turn the car off and let the clutch out. If I was to pull into my parking spot, push the clutch down, turn off the motor, then try to put the car in reverse it is very difficult.
Do others have this problem, is it very difficult to get the car to shift into reverse when the car is off?
Old Dec 21, 2006 | 05:23 PM
yellohvette's Avatar
yellohvette
Originally Posted by ratman228
Hello,
yes, it is very tough to get the car into reverse with the ignition turned off. However, if you find yourself in that situation, just turn the key to on without starting the car (read: turn on the full accessories, etc). This should allow the reverse lockout solenoid to get out of the way and let you put it in reverse.
I can't comment on the fact whether reverse or first is better, but i think that sort of depends on which way you are facing on the hill...if you are facing nose down, i would recommend REVERSE and vice-a-versa.
I think that is about it...anyone else have anything to add?
Old Dec 21, 2006 | 07:52 PM
SLO C5's Avatar
SLO C5
From: Are you fat because you're lazy or lazy because you're fat? San Jose, CA
Cruise-In X Veteran
St. Jude Donor '09
Default my advice
Sometimes I have trouble getting it into reverse as well. Instead of trying to force it in there, just put the shifter into 1st, then go over to reverse and it is smooth as butter.
Old Dec 21, 2006 | 09:10 PM
cruisemon's Avatar
cruisemon
You REALLY don't want to use 1st gear to hold your car on even a modest grade. Don't ask how I know (hint - it's a beeyach to catch your ride after about the first 12-15 feet). Use reverse and if the grade is moderately steep, use the emergency brake as well.
Charlie
Old Dec 21, 2006 | 09:39 PM
Bill Dearborn's Avatar
Bill Dearborn
Sometimes the gears clash when you are trying to shift into reverse. I have found the best way to avoid this is to leave the motor running, shift into reverse and while still pushing on the shifter let the clutch out slowly. If it isn't in reverse the shifter will slide forward so reverse is fully engaged and if it is already in reverse the tach will drop slightly as you engage the clutch. Either way once you know it is in reverse push the clutch in and turn off the motor.
By the way I live on a steep hill and do not need to use the parking brake when the car is in low or reverse. It doesn't have a rice motor so there is enough compression to hold the car in place.
Bill
Old Dec 22, 2006 | 12:31 AM
BlackZ06's Avatar
BlackZ06
Having lived with the hills of San Francisco for many years, here's my advice ...
First, curb your wheels ....
If the car is pointing uphill, turn the front wheels all the way to the left (as if you were turning left) before shutting off the engine and let the front right wheel settle against the curb. If facing downhill, turn the front wheels all the way to the right. This is the law in SF, you'll get ticketed if you don't park this way.
Second, you don't want to spin the motor backward if the car does get away. If the car is facing uphill, put it in reverse. If it is facing downhill, put it in first.
The combination of your parking brake, curbing your wheels, and leaving the car in the (correct) gear, should prevent a "runaway".
Old Dec 22, 2006 | 05:58 AM
Oldvetter's Avatar
Oldvetter
I believe it takes about 15 pounds force to overcome the reverse lockout with car off (may have to use both hands). You use reverse beacause it is a lower gear and offers most resistance to moving.
Old Dec 22, 2006 | 08:07 AM
VetteDrmr's Avatar
VetteDrmr
The main reason Reverse is recommended is because it's a lower gear than first, and therefore will hold the car better.
Not sure I agree with the comment about spinning the engine backwards: the engine is at rest, there's not attempt to get it to run, and the mechanicals will work as well going backward as forward.
HTH, and have a Merry Christmas and Happy New Year!
Mike
Old Dec 22, 2006 | 08:30 AM
65GGvert's Avatar
65GGvert
You'll be sorry if you "curb your wheels".
Old Dec 22, 2006 | 09:21 AM
cruisemon's Avatar
cruisemon
The practice is a safe one. The price for doing it improperly is high. It is REALLY easy to ugly up a $3000 set of wheels. On the other hand, havin' that bad boy roll off down the hill and smack something could be expensive as well.
Has anyone ever tried parking on a hill but putting your car perpendicular to the side of the road? Then all you gotta be worried about is someone tipping it over. Well, that and some Barney Fife looking to make a name for himself writing you a ticket and towing the car away.
Charlie
Old Dec 22, 2006 | 09:24 AM
BlackZ06's Avatar
BlackZ06
You'll be even sorrier if you don't in SF ....
Why do you think this is a bad practice ??
Old Dec 22, 2006 | 09:34 AM
burbleflyer's Avatar
burbleflyer
St. Jude Donor '08
I live in central Florida. What is this "hill" thing you speak of?
Old Dec 22, 2006 | 09:47 AM
BlackZ06's Avatar
BlackZ06
If the car "runs away" on a hill the engine will be "running" (no ignition, but it will be spinning if the car is in gear), and if you have it in first and the car is going backwards ... the oil pump is scavenging oil from the engine, not feeding it oil pressure. Though, by the time the car stops, the least of your worries might be the condition of the engine
Old Dec 22, 2006 | 09:48 AM
cruisemon's Avatar
cruisemon
You know those places up around Orlando, when the snow melts and then refreezes and gets slicker than owl feces, and then when you realize the front end of your car is at a lower position than the rear end of your car and they swap rapidly so that now the rear is lower than the front? That's a hill.
Charlie
Old Dec 22, 2006 | 09:51 AM
cruisemon's Avatar
cruisemon
about SFO. I think the reference to "bad practice" relates more to those who don't do it all the time that don't turn the steering wheel all the way over to the lock but rather turn the wheel only slightly. Turn slightly, run into curb, damage wheels.
I still think the perpendicular to the street idea is worth trying if someone has the stones to do it (I don't).
Charlie
Old Dec 22, 2006 | 09:53 AM
ratman228's Avatar
ratman228
Ok, Thanks for the re-assurance guys. It's nice to be able to talk to other vette owners and see if they have similar issues. In my neighborhood, it is hard to find another vette owner.
Old Dec 22, 2006 | 09:57 AM
BlackZ06's Avatar
BlackZ06
Charlie
Actually some streets in San Francisco (Russian Hill area, for example) are so steep that the parking is laid out perpendicular to the curb.
Biggest problem with this is if your car doors are heavy, depending on which side you're on, either getting out of the car can be a pain (facing uphill) or not smashing the door into the car parked below you (facing downhill) can be difficult too.
To Question about MN6 Reverse Shifting
Old Dec 22, 2006 | 10:39 AM
Jet-Jock's Avatar
Jet-Jock
Your from Zepherhills. Don't you folks have all the hills over there?
Yeah us flat-landers hardly worry about this stuff.
Old Dec 22, 2006 | 12:19 PM
burbleflyer
St. Jude Donor '08
I used to date a girl who could lay down and taller mounds than ZHills has!
I'ts flatter than **** on a plate here.
Old Dec 22, 2006 | 06:47 PM
65GGvert's Avatar
65GGvert
If I had to, I might curb my tires. I don't want my wheels curbed.
