Car locks gone crazy
Old Dec 22, 2006 | 07:02 PM
Charley Hoyt's Avatar
Charley Hoyt
Default Car locks gone crazy
The locks on my car have a mind of their own...The car locks and unlocks at will. Sometimes doing it 4 or 5 times in a row. Has anyone else heard of this. What could cause this???
Thanks for the help.
Old Dec 22, 2006 | 07:19 PM
LoneStarFRC's Avatar
LoneStarFRC
Slide the switch on your key fobs to the "off" position.
Old Dec 22, 2006 | 07:27 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Yep,,,,you have the FOB flew!
On a more serious note, you could have a bad FOB. Do you have more tham one FOB?? If so, the bad one should be easy to figure out. They do go bad!
BC
Old Dec 22, 2006 | 08:48 PM
65GGvert's Avatar
65GGvert
What Lonestar said, turn the passive switch on your fobs (both if you have 2) to the off position. I read a post recently where the guy had an extra fob in his tool box in the garage and it intermittently locked and unlocked his doors. Move them far away and see if you still have the problem.
Old Dec 23, 2006 | 01:33 AM
Charley Hoyt
I have already tried all of the obvious things....I guess I should have given a little more information in my original post.
This started a couple of weeks ago when I changed my battery. Within a day or so of installing the new battery the fob stopped working. I tried reprograming it...That worked for a short period of time. When I returned to the car the fob wouldn't work again. I tried reprograming several more times with the same results. I also tried doing it with my other fob. Then I put new batteries into both fobs and tried it again. During one of the programings I stayed in the car for about five minutes thinking through why the car forgot the programing. After a few minutes the locks would unlock...then they would lock again. Sometimes it would lock and unlock four or five or more times. Then it eventually looses the programing and the fobs don't work. The only DTC codes I am getting are U1064 for the LDCM and the RDCM. The ony thing I can think of is that I must have a short someplace, or the DCM's are having trouble communicating with the BCM???
I should also mention that I tried putting the fobs out of range and I have the same problem.
Hopefully the additional information helps.
Old Dec 23, 2006 | 03:48 PM
LoneStarFRC
The "U" is a "loss of communication" code and not all that uncommon as long as there are no failures present. Especially if it has an "H" (history) at the end of the number. If you have put the FOBs out of range and you are still getting spurious activation/de-activation of the door locks, there may be issues with the BCM. I think it highly unlikely that both DCMs would fail simultaneously. Have you ever experienced water/moisture on the pass. floorboards in the past? That's where the BCM is located and this has been known to cause all sorts gremlins.
Old Dec 23, 2006 | 05:11 PM
John G Pircsuk's Avatar
John G Pircsuk
I had this problem on my C4. Until I noticed that the AC wasn't working I ignored it for a few days. It turned out to be a loose ground. Ground was fixed and both symptoms went away.
Old Dec 23, 2006 | 05:42 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
John
C4's had some ground issues; C5 are ground issues waiting to happen!
GM did a great job on protecting the +12 VDC plugs and connectors with WEATHER TIGHT connectors! They FAILED on the ground side!
If you have a C5 and have electrical problems, you should be looking at the ground path of the circuit in question prior to dropping wads of cash on replacement parts!
You are double prone if you drive your car year around and in increment weather! On the other side of the coin,,,,,your not exempt if you have a garage queen with 5000 miles on the odometer!
Check and clean your grounds!
GM seemed to have made ground (PUN! ) on the C6! Their grounds seem to be rock solid! There an eyelet type of ground vise the connector type.
Check an clean your grounds. A decent cleaning solvent for the connectors is:
A decent corrosion preventive treatment for the exposed ground connectors is:
If you have electrical issue questions, give me a PM!
BC
Old Dec 23, 2006 | 06:37 PM
1999WHITEFRC's Avatar
1999WHITEFRC
LOL,That was me!
Old Dec 23, 2006 | 08:34 PM
Charley Hoyt
Originally Posted by Bill Curlee
John
I checked all of the grounds...at least I think I found them all . All of the ground packs are clean and in good condition.
Today I checked the BCM and every thing "looked" fine. No moisture...connections looked clean. I also took out the battery and battery tray....some battery acid was evedent...I used baking soda to neutralize the acid....which made a bigger mess. I also checked the connections to the PCM...and they were clean...althought the wires had a lot of dried baking soda on them. I hope I didn't make the problem worse. The condition remains the same...The computer learns the remotes...then after a few minutes the doors unlock and lock repetidly until the code gets erased.
This is really getting frustrating.
Old Dec 25, 2006 | 02:08 PM
Charley Hoyt
any other inputs? This one has me stumped????
Old Dec 25, 2006 | 02:34 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
open the fob, cut the 'shaker' from the circuit board
But first, with the fob STILL does the car unlock/lock on it's own, if the fob moves and it does this then cut the shaker
i have done this to my fob, it was tough, but i got over it
Old Dec 25, 2006 | 04:56 PM
rapid robert's Avatar
rapid robert
Steve,
Mine do the same thing. Lock and unlock at will. What is this shaker part you talk about?
Thanks Bob
Old Dec 25, 2006 | 05:10 PM
SteveDoten's Avatar
SteveDoten
Originally Posted by rapid robert
Steve,
Thanks Bob
97-99 car? grab a penny open the fob, see the 'shaker' on the circuit board, you can hear it
if the switch is 'off' and the fob makes the car lck/unlck, then cut it
Old Dec 25, 2006 | 05:15 PM
Charley Hoyt
It seems to do it regardless of movement. I was experimenting with my number 2 remote today... and with this one I didn't get the repeated locking an unlocking...but after about five minutes the car forgot the code for the remote and the remote stopped working. It is strange that the remote works for a few minutes...and then it stops working????
Old Dec 25, 2006 | 05:22 PM
SteveDoten's Avatar
SteveDoten
Isolate all variables
new battery in fob2?
car locks when fob is absolutely still?
then read Bill Curlee's post, sounds like your BCM is taking a bath from the hvac system, very common problem
Old Dec 25, 2006 | 05:52 PM
Charley Hoyt
I put new batteries in both Fobs
Car does lock when the Fob is absolutely still with fob #2. I will have to try Fob #1
I checked the BCM and it is dry and I checked the connections on the BCM and they are fine.
This one is really stumping me...
Old Dec 25, 2006 | 07:52 PM
Charley Hoyt
I checked Fob # 1 and it does lock the car when I move the remote...I cut the shaker....and that worked for a while. Then after a couple of hours the remote stopped controling the car????
Old Dec 26, 2006 | 07:34 PM
Charley Hoyt
Any other ideas why the car would forget the code every couple of hours? I can resync by pressing both lock and unlock at the same time and then the remotes work again for a couple of hours. This is strange.
To Car locks gone crazy
