alignment suggestions
Old Dec 27, 2006 | 02:13 PM
bluvette79's Avatar
bluvette79
Default alignment suggestions
i am convinced that i need to put gs d3 tires on my 99 vert, thanks to what i have read in forum. good wet traction as well as dry. now i need to know if there is anything specific i should tell the alignment folks or will it come directly from their charts? i think ntb will be doing the tires and alignment. just normal driving (for a vette! ) no autox or track time planned. anything i need to make sure they do or check?
thanks as always
jim
Old Dec 27, 2006 | 03:36 PM
Bill Dearborn's Avatar
Bill Dearborn
The charts allow a lot of leeway for an alignment that meets specs. You should tell the tech you want the service preferred setting and there should be no + or - tolerances. Otherwise you can be in spec and have an alignment that is totally wrong for you. The specs are:
Wheel Alignment Specifications
RPO
Operation Service Preferred Tolerance
Front Alignment Specifications
All
Front Individual Toe + 0.04 +/- 0.10
All
Front Sum Toe + 0.08 +/- 0.20
All
Steering Wheel Angle 0.0 +/- 1.0
FE1 & FE3
Front Individual Caster + 7.4 +/- 0.5
FE1 & FE3
Front Cross Caster Within +/- 0.5 --
FE1 & FE3
Front Individual Camber - 0.20 +/- 0.5
FE1 & FE3
Front Cross Camber Within +/-0.5 --
Rear Alignment Specifications
All
Rear Individual Toe - 0.01 +/- 0.10
All
Rear Sum Toe - 0.02 +/- 0.20
All
Rear Thrust Angle 0.0 +/- 0.10
FE1 & FE3
Rear Individual Camber - 0.18 +/- 0.5
FE1 & FE3
Rear Cross Camber Within +/- 0.5 --
Bill
Old Dec 27, 2006 | 06:50 PM
bluvette79's Avatar
bluvette79
thanks bill. i'll print your post and give it to them. i guess they will know what fe1 and fe3 are!
jim
Old Dec 27, 2006 | 06:57 PM
bcseitz's Avatar
bcseitz
Have an experienced Corvette allignment shop simply do a Z06 spec allignment.
Perhaps go a tad easier on the neg. camber on all fours if you don't want the tire wear on the insides like Z's tend to have.
Make sure you raise or lower the car where you want it before you have the allignment done.
Bob
Old Dec 28, 2006 | 10:48 AM
bluvette79's Avatar
bluvette79
thanks for the info. i haven't hooked up with a c5 club in the st. louis area as yet so i am not sure if there are any corvette experienced shops around but i will be looking. i'll call around!
jim
To alignment suggestions
