COMMENTS ON FIRESTONE FIREHAWK - RUN FLAT TYPES
Old Sep 29, 2001 | 12:34 AM
TURBOTOC's Avatar
TURBOTOC
Default COMMENTS ON FIRESTONE FIREHAWK - RUN FLAT TYPES
ANY ONE WITH EXPERIENCE, GOOD OR BAD WITH FIRESTONE FIREHAWK RUN FLAT TECHNOLOGY (RFT) = FIREHAWK SZ50 EP RFT TIRES?.
I AM CONSIDERING REPLACING MY GOODYEAR EMT'S WITH THE FIREHAWKS ON MY 2000 COUPE.
Old Sep 29, 2001 | 12:55 AM
Godspeed's Avatar
Godspeed
Senior Member
Cruise-In III Veteran
Cruise-In IV Veteran
Default Re: COMMENTS ON FIRESTONE FIREHAWK - RUN FLAT TYPES (TURBOTOC)
Don't use all capital letters, it's interpreted as yelling.
P.S. I have them up front on my 99 and I like them.
[Modified by Godspeed, 10:38 AM 9/30/2001]
Old Sep 29, 2001 | 02:24 AM
SR1654's Avatar
SR1654
I have them on my 98 coupe and they are decent tires. I recently got the car and they came with it so unfortunatley I have not been able to compare them to the GY's. But I have heard from other forum members that they are a lot better than the GY's. Good luck! :seeya
Old Sep 29, 2001 | 02:28 AM
jtaylor's Avatar
jtaylor
Just changed over about three weeks ago. Much Quieter! Seems to give better traction. Very satisfied.
Old Sep 29, 2001 | 02:31 AM
Nilla Ice's Avatar
Nilla Ice
Default Re: COMMENTS ON FIRESTONE FIREHAWK - RUN FLAT TYPES (Godspeed)
Don't use all capital letters, it's interupted as yelling.
interrupted? :lol: Interpreted... :p:
Old Sep 29, 2001 | 03:06 AM
XmentalPilot's Avatar
XmentalPilot
From: "Once you have flown, you will walk the earth with your eyes turned skyward; for there you have been
I just replaced my Goodyears (Wednesday) So far I am very pleased with the Firestones http://forums.corvetteforum.com/zerothread?id=157737
Old Sep 29, 2001 | 05:29 AM
teeceemv's Avatar
teeceemv
Had mine about a month now. No question they are quieter and smoother. Grip is better. They will only go 50-60 miles flat as opposed to the Goodyears which will go 200 miles flat. Also I noticed that "turn in" is not as crisp as with the Goodyears, likely a result of the rounded shoulder.
Overall, considering the price difference, I'd say the are a hell of a good tire.
TC
Old Sep 29, 2001 | 09:06 AM
2000^C5's Avatar
2000^C5
From: My barber didn't know when to quit... Do you?
I like mine, much better than the GYs! :smash:
Old Sep 29, 2001 | 09:07 AM
Peach's Avatar
Peach
Orlando Events Coordinator
Cruise-In II Veteran
I have them and love em.
Old Sep 29, 2001 | 12:34 PM
Kenny94945's Avatar
Kenny94945
Hi, I have run them for 6 months.
Rim protector...is cool not a visable eyesore for me.
Width...They do look a little smaller, because of the roundness (instead of square drop off on GY) to the sidewall.
Traction...Dry weather on straightline acceleration seems OK.
Traction ...Wet ????????
Grip...acceleration they kind of feel soft or greasy in corner. Control and slide is predictable. OK.
Braking...my only grip. They tire "bark" under braking runing my stealth approach to driving. I do not recall the GY barking as much.
Quietness...NOCTICABLE quieter road noise that GY.
So......based on road noise and straightline grip definitely preform better than GY.
Myself...I will try the BF Goodrich KD SSS next tire purchase. Michelin is the other option.
Old Sep 29, 2001 | 02:52 PM
Mike Siska's Avatar
Mike Siska
I've had mine on for 4,000 miles and they are soooooo much better than the Gy's. No more pounding on me or the vette when you hit those manhole covers or ridges in the road that you want to drive around but just can't (car next to you). I just wish they wouldn't sidestep when my PLII vette either downshifts from third to second, or upshifts from first to second. :D :D :D :D
Old Sep 29, 2001 | 03:51 PM
RPO_Z06's Avatar
RPO_Z06
St. Jude Contributor
Default Re: COMMENTS ON FIRESTONE FIREHAWK - RUN FLAT TYPES (Mike Siska)
I like mine and currently have around 3K miles on them and they still look new.
Old Sep 29, 2001 | 04:08 PM
Bill Dearborn's Avatar
Bill Dearborn
Default Re: COMMENTS ON FIRESTONE FIREHAWK - RUN FLAT TYPES (White_98)
I haven't tried any high g launches with them but they seem to corner as well or better. The only thing I really notice is a low growling noise that comes from the back tires. They seem to make the same volume of noise as the Goodyear just a different type of noise. At first I thought I had a diff problem but the noise is constant whether the clutch is in or out. The noise could also be due to my running max negative camber in the rear.
Bill
Old Sep 30, 2001 | 12:44 AM
TURBOTOC's Avatar
TURBOTOC
Godspeed:
Thank you for the information.
I did not know that capital letters were "interpreted" as yelling. In the Marine Corps all messages are sent in capital letters.
Turbotoc
Old Sep 30, 2001 | 03:43 AM
FunDriver's Avatar
FunDriver
Veteran: Marine Corps
Godspeed:
Turbotoc
Don't worry about it...we all have to learn and most of us have made mistakes one way or another. Semper Fi.
Old Sep 30, 2001 | 12:24 PM
alanh's Avatar
alanh
Default Re: COMMENTS ON FIRESTONE FIREHAWK - RUN FLAT TYPES (FunDriver)
From my experience in the service, much of the communication in the Marines was quite loud, could be considered as "yelling", the "all capps" communication from TURBOTOC might be quite appropriate for his daily lifestyle. :D
Old Oct 1, 2001 | 11:03 PM
TURBOTOC's Avatar
TURBOTOC
Thanks to all of you for responding to my question about Firestone Firehawk RFT's. I have ordered a pair for the rear and I will keep you posted.
Thanks Again,
TURBOTOC
To COMMENTS ON FIRESTONE FIREHAWK - RUN FLAT TYPES
Old Oct 2, 2001 | 12:29 PM
carpe dm's Avatar
carpe dm
Thanks Again,
TURBOTOC
This may be Ok, but it is generally better to run all four the same. :yesnod:
Old Oct 2, 2001 | 03:37 PM
mozin's Avatar
mozin
I would also suggest replacing the front tires so that all four tires are matched.
Tom
Old Oct 2, 2001 | 04:13 PM
Mike Siska's Avatar
Mike Siska
Default Re: COMMENTS ON FIRESTONE FIREHAWK - RUN FLAT TYPES (mozin)
Tom
I would do the same. Match all four if you can. By the way, at Capital Drag Raceway in Crofton, Md. last friday night, I did a 13.14@107mph with the FS's :cheers: :D :D :D
