C5 Climate Control dim/dark display fix
Old Nov 22, 2008 | 10:57 PM
  #141
The Villain's Avatar
The Villain
i was checking radioshack earlier, closest i could find were a couple 40mA LEDs:
http://www.radioshack.com/product/in...3&tab=features
will these work ok? thanks for the great info!!
Originally Posted by tstar
The backlight bulbs all run in series off one circuit;
Radio Shack sells a 60ma bulb that is very close to the stock 70ma. I recommend replacing all of those at once...
The LEDs are controlled by the buttons each one represent but I'm not sure where that circuitry goes. If you have a few LEDs out try replacing them...
And that's all I know!
Old Nov 23, 2008 | 12:59 AM
  #142
tstar's Avatar
tstar
St. Jude Donor '11-'12-'13-'14-'15
NO... not as a direct replacement. LEDs must be installed with an appropriate resistor before they can function in place of the stock bulbs.
The stock bulb is a 70mA incandescent bulb and can be purchased here;
http://www.corvetteradios.com/corvetteradios_013.htm
There are some 60mA bulbs available also that are more readily available.
Tim
Old Nov 23, 2008 | 02:30 AM
  #143
lucky131969's Avatar
lucky131969
What capacitors???
Tim
Not familiar with surface mount caps, huh?
Old Nov 23, 2008 | 04:13 AM
  #144
tstar's Avatar
tstar
Somewhat... I've never dealt with SMT Caps that were black and marked "241". The ones I've known always seemed to be brownish in color and had no markings.
Tim
Old Nov 23, 2008 | 08:45 PM
  #145
lucky131969
Tim
I never said they were black, or marked 241. And yes, they are typically brown or yellow in color.
Old Nov 24, 2008 | 12:48 AM
  #146
tstar's Avatar
tstar
Originally Posted by lucky131969
Yep, mine just went out last month Bill. I touched up the surface mount resistors and caps....works like a charm.
OK... Then what Capacitors were causing your display to dim out on you? Or did you re-solder everything just in case?
Tim
Old Nov 24, 2008 | 01:00 AM
  #147
lucky131969
Tim
I touched everything up. I can't tell you specifically what resistors had cracked solder joints either(without a scope), but I hit them all.
Old Nov 24, 2008 | 01:10 AM
  #148
tstar's Avatar
tstar
Smart man!!!! I was curious when you mentioned Caps. I'm like "That damn Lucky knows something I don't... AGAIN!"
Tim
Old Nov 24, 2008 | 11:42 AM
  #149
The Villain
awesome, thanks a lot for the info tstar!
Old Nov 24, 2008 | 03:48 PM
  #150
tstar's Avatar
tstar
Anytime!!
Tim
Old Nov 25, 2008 | 01:20 PM
  #151
metalikobject's Avatar
metalikobject
5th Gear
The soldering fix worked for me . No more dim readout! Anyone who is hesitant to do this fix themselves shouldn't be the process is straight forward. The only thing you'll need to have is patience, that and the tools of course. Thanks for the help!
Jason
Old Dec 27, 2008 | 02:52 PM
  #152
The Villain
Default broken resistor
d'oh!
so while resoldering these i slipped and broke one of the 241 surface mount resistors with my tweezers. anyone know where i can get a replacement? by any chance is there something i could score from radioshack that would do the trick? thanks!
Old Dec 27, 2008 | 03:51 PM
  #153
nextime's Avatar
nextime
Radio Shack sucks. There should be some type of electronics distributor near you, check local TV repair shops and they can let you know where they buy their transistors and stuff from. These types of stores make Radio Shack look like Walgreens.
Old Dec 27, 2008 | 05:56 PM
  #154
The Villain
no luck with radioshack. found a place online that has them:
http://www.westfloridacomponents.com...Store_Code=wfc
the 241 means its a 240 ohm resistor. (24 x 10^1)
woohoo! i learned something new.
Old Dec 30, 2008 | 05:06 PM
  #155
Blue LS1-LT1's Avatar
Blue LS1-LT1
Mediocre soldering skills here...This fix worked anyway! Great post!
Happy New Year to me!!!
Old Dec 30, 2008 | 08:13 PM
  #156
Slick Rick's Avatar
Slick Rick
Ill be doing mine thurs. Ill try and put some before and after pics.........
Old Dec 31, 2008 | 07:12 AM
  #157
ninjazed's Avatar
ninjazed
Nobody who has the dim HVAC display defect in their car needs to endure it like I did. Like an idiot, for many months, I either tapped on the screen to brighten it a bit or I guessed at the settings. Now I consider myself kind of handy (I did the headlight gear fix myself) but I was really wary of soldering a circuit board in my C5. I finally got my butt in gear, removed the module and sent it to CF member tstar in PA. He's one of the trained pros on this forum with regards to lighting. My display was back within days and all I can say is it's great to have the HVAC control module shine like new again. He even replaced some burned out command button bulbs for me. I'm not saying that people shouldn't try it themselves if they are so inclined, but don't live with this defect any longer than you have to. If you're afraid of breaking something (like I was), there are forum members here that will save you big $$ and hook you up. From what I have heard, even if you purchased a new module from GM, the solders are lame on those units as well. <end of rant>
Thanks again Tim and Happy New Year everyone!
To C5 Climate Control dim/dark display fix
Old Jan 1, 2009 | 02:03 PM
  #158
Slick Rick's Avatar
Slick Rick
First of all I want to thank everybody that has posted information on how to do this yourself. Anybody who thinks they dont have the talent or skills to do this dont think that way. This is a very simple do it yourselfer if you use the info from these posts. Also for us 97 owners its over a 400.00 savings. Took all of an hour to do the whole job. And my display is as bright as the clocks again. I didnt do pics sorry for that. But it sure is nice to have a display I can see again........... Thanks to all and have a great New Year.............
Old Jan 1, 2009 | 03:32 PM
  #159
Patman's Avatar
Patman
When my climate control head unit display went dim in early 2005, I didn't know about the simple fix on this forum, and had a GM dealer replace the unit. That was very costly up here!
And earlier this summer, that unit started going dim too, so the replacement units that GM is selling are just as bad if not worse than the original ones! You'd think they would learn and make them better but then don't care!
Eventually I'll get around to fixing it (definitely not in this brutally cold weather, I hate working on the car in the winter!), but mine hasn't gone completely dim yet and sometimes it'll go completely bright for a few weeks at a time, so it's not that much trouble for me yet.
Old Jan 1, 2009 | 09:36 PM
  #160
The Villain
following up on my earlier post about busting one of those surface mount resistors, i have quite a few extras of these now, so if anyone else screws up and needs one, feel free to PM me and I'll throw one your way.
thanks a ton to everyone thats contributed to this thread, this is terrific info!
