C5 Climate Control dim/dark display fix
Old Jan 2, 2009 | 12:13 AM
  #161
510picker's Avatar
510picker
I fixed my dim display today. Thanks for the write up and I encourage anyone suffering from this common problem to dive in and fix it. If I can do it, anyone can do it.
Old Jan 3, 2009 | 02:00 AM
  #162
tstar's Avatar
tstar
St. Jude Donor '11-'12-'13-'14-'15
FYI...
http://forums.corvetteforum.com/1568405159-post64.html
Tim
Old Jan 3, 2009 | 01:08 PM
  #163
Greenlight88's Avatar
Greenlight88
Default HVAC control module
Thanks for the great info. Would you recommend disconnecting the battery ground wire first?
Old Jan 3, 2009 | 01:54 PM
  #164
lucky131969's Avatar
lucky131969
Disconnecting the negative battery cable is step #1 when replacing the auto control assembly.....right out of the service manual.
Old Jan 3, 2009 | 08:12 PM
  #165
Greenlight88
I have the same HVAC control module circuit board that you posted. I have it in front of me, but can see nothing wrong with any of the connections. The 241 resisters in the center of the board all appear to be properly soldered. You really can't even see a solder connection on them, they're almost flush to the board. Can you normally see a broken soldered connection? None appear loose.
Old Jan 3, 2009 | 08:20 PM
  #166
Slick Rick's Avatar
Slick Rick
Nope you cant see the bad connections. Mine all looked good until I started soldering them and they would fall off the board. I noticed on mine most the bottom solders were the bad ones. So I soldered bottom first then top..... It works like new now. Hit them all and youll be good to go .......... Rick
Old Jan 3, 2009 | 08:35 PM
  #167
Greenlight88
all the soldering is on the top side of the board, right? I've never done circuit board soldering before. any basic soldering tips to offer?
Old Jan 3, 2009 | 08:37 PM
  #168
Greenlight88
should I just be soldering the 241 resistors? Is everything on the board a resistor?
Old Jan 3, 2009 | 08:41 PM
  #169
lucky131969
If you have not soldered before, I have to be honest, I would stop right now.....it's real easy to screw something up.
Old Jan 3, 2009 | 08:56 PM
  #170
Greenlight88
Thanks. I might know someone thats done this before. I may just call him first. I did stop by Radio Shack and buy a Cold Heat soldering tool, but have never soldered anything this small before.
Old Jan 3, 2009 | 09:24 PM
  #171
Slick Rick's Avatar
Slick Rick
If it were me Id take the cold heat tool back and get the 15 watt grounded iron. It has a very fine tip and is very simple to use. When I did mine i had magnifying glass in one hand and soldering iron in other hand. Ive had some soldering exp. but with nothing this small and didnt have any problems at all. Just take your time and go slow.......
Old Jan 3, 2009 | 11:34 PM
  #172
nextime's Avatar
nextime
The cold heat soldering tool is a joke, I bought one and got one as a gift and both work like crap. Get the 15 watt soldering iron.
Old Jan 4, 2009 | 02:45 AM
  #173
tstar's Avatar
tstar
Although not the hardest of soldering jobs by any means I have to echo Lucky's advice. If you've NEVER soldered before now is not the time to start... give your buddy a call to assist you!
A 15 watt iron is a good choice for this job if you don't have access to a dedicated SMT rework gun...
Tim
Old Jan 4, 2009 | 02:50 AM
  #174
tstar's Avatar
tstar
Here's small...
I replaced the stock Orange LEDs in the Driver's door switch with Red ones, that's a 3mm and a 5mm next to it... Now THAT was a PITA!
Old Jan 4, 2009 | 07:11 AM
  #175
Greenlight88
that's really small. I don't think I'll be trying that for a while!
Old Jan 4, 2009 | 08:59 PM
  #176
Greenlight88
Just wanted to report back. I ended up returning the cold heat soldering tool, and bought a 15A grounded soldering tool. worked perfect. One of you suggested using a toothpick to hold the resisters in place while applying the solder. That worked great. Everything is back together and the display works like new.
My biggest challenge ended up being reconnecting the fuel door electric switch. The pigtail was too short to reconnect as instructed, so I ended up removing the switch from the console first, plugging the connector into the switch, reinstalling the console, then reaching under the console and snapping the switch back into the console.
Thanks for all the help!
Old Jan 5, 2009 | 01:02 AM
  #177
tstar's Avatar
tstar
Tim
To C5 Climate Control dim/dark display fix
Old Jan 5, 2009 | 09:42 AM
  #178
Blue LS1-LT1's Avatar
Blue LS1-LT1
Umm, it worked fine for me. The tip was a little annoying, and took some getting used to, but, it worked as advertised and didn't burn anything which is everyone's major concern.
I placed the solder parallel to the "241"'s to get it to stick. It didn't take much and my display is back to new.
I hope it stays that way.
Old Jan 7, 2009 | 08:48 PM
  #179
The Villain's Avatar
The Villain
well, the resistors i ordered were the correct impedance but the wrong size by far. anyone know of a place to order the correct 240ohm resistors for this board? thanks!
Old Jan 7, 2009 | 08:56 PM
  #180
tstar's Avatar
tstar
I have some parts boards that I can take some resistors off for you if you can't score new ones...
Tim
