Clearing codes
Old Sep 29, 2001 | 07:51 AM
K&B Motorsports's Avatar
K&B Motorsports
Default Clearing codes
How do you clear dic codes?
Old Sep 29, 2001 | 08:17 AM
C5Cemo's Avatar
C5Cemo
Default Re: Clearing codes (oracleguru)
Once you've got the diagnostics up and running all you need to do is push/hold the reset button.
You can acess all of the cars trouble codes from the dic and erase them! I know it works on my 99 but, I am not so sure on the earlier C5's. Here is what you do:
Press and hold options and then press Fuel 4 times while still holding the options button you must do this quickly. A message will appear saying "Diagonstics" then it will automatically read off the codes. Like....02-PCM(No codes)....03-BCM(No Codes)...ect. if there is a code it will look something like this 02-PCM (1052H) NOTICE THE H at the end of the code, That represents a code that has happened in HISTORY. If there is a C after the code it is CURRENT.
To clear the codes let it automatically cycle through the codes then it will come to (MANUAL DIAGNOSTICS) this is where you can clear codes. Use the options button to scroll forward and the TRIP to scroll backward find the code(s) to be erased like 02-PCM (2Codes). To erase this, press and hold the reset button until it says "NO CODES" There you have done it!!!. To exit the Diagonstic menu press the METRIC BUTTON!!!
-IH8PONYS
Old Sep 29, 2001 | 08:24 AM
K&B Motorsports
Bill
Old Sep 29, 2001 | 10:05 AM
sandbagger's Avatar
sandbagger
On an unrelated note can you guru my Oracle stock back into the stratosphere? lol
:flag
Old Sep 29, 2001 | 10:11 AM
K&B Motorsports
Default Re: Clearing codes (sandbagger)
Sure, if you fix my siebel and i2 stock :cheers:
Old Sep 29, 2001 | 10:25 AM
sandbagger's Avatar
sandbagger
Consider it done!
How soon can I expect to see your magic? lol
Do you work for Oracle? :flag
Old Sep 29, 2001 | 02:39 PM
K&B Motorsports
Nope...
Was an independent for nearly 20 years before going permanent (full time) with another tech firm. Spent 15 years doing nothing but working with Oracle implementations.
Bill
To Clearing codes
