Catch can???
This is what my can caught after 800 miles . . .
. . . and this week after another 2900.
So I say that to say this. If you are using oil between changes you maynot need a catch can. My $.02c
SLPRC5
A couple of questions:
Do you have any comparison on how much the coalescing filter removes versus a "normal" catch can?
Instead of making a new larger reservoir, how about attaching a a piece of hose (it can just hang down) where the drain fitting goes on the stock cup and using that hose as the reservoir? The existing drain fitting could go on the lower end of the hose.........
DID YOU MACHINE THE OVERSIZED RESEVOIR, OR CAN THIS BE PURCHASED?
HOW OFTEN DOES THE FILTER ELEMENT NEED TO BE REPLACED?
Cheers, Curt
I thought about an alternative that is similar in concept. A glass jar is screwed to the filter's zinc reservoir with a screw that has a hole drilled in it. This screw would be sealed by using an o-ring washer against the jar lid. Your method would work as well, although it may look kinda funny. You can get a large diameter hose and neck it down using various fittings.
I have been using particulate and coalescing filters in compressor lines for years and have yet to have to replace a filter. I'd guess that it is good for many years.
I have been using particulate and coalescing filters in compressor lines for years and have yet to have to replace a filter. I'd guess that it is good for many years.[/QUOTE]
I SENT YOU A PM.
In a one hour road race situation, all first and second gear (to 6000+ rpm) rarely a straight away to get into third, I used almost one quart of Mobile 1. Yet I can drive 900 miles on the interstate averaging 71 mph in 11+ 30 off the trip computer and not burn a drop.
This high RPM, on/off the throttle must generate allot of oil mist and a small catch can will be full (I would think) in a short time.
I wonder if a tight fitting "windage tray" around the crank would help and if the crankcase ventilation system flows too much air so as to pick up all the oil flying around at high RPM and backing of the throttle from high revs (High manifold vacuum) for the next corner.
I was going to a DE at VIR but after this, I'm not comfortable with this oil use situation.
The oil Low level light doesn't come on (on my car) until I crank it up after a gas stop. This is not a good feeling (Oh my poor baby what have I done to you!), (a Qt. of oil in a zip bag, fits nicely between the battery and the fuse box)
Mechanical things that cause this are Piston ring flutter but my engine is too low time for this to be a consideration.
Again in norm fun driving oil use is minimal.
I've installed a Gulf Coast Performance can but haven't driven the car yet.
Curt
1999 Pewter/Grey Coupe, Z-51, 6mn.
Mods:AFR 205s, Comp 224* .580" 112*+2*, PRC Gold w/Ti retainers. Z06 Oil Pump, Double Chain timing set. LS6 Intake, Big K&N, no air box, Dynotec SuperMaxx headers/no cats, Corsa X and PaceCar mufflers. Hurst shifter, Hotchkis Bars, Z06 Shocks. Fikse Classic Aro Forged 3 piece 18"x9.5", 18"x10.5". Michelin PS2, 265/35 & 315/30, EFI FlashScan, LM-1 controller.
Dave
EWEBABY, I replied to your PM. If we can get another 6 people who are interested, I can place another order of filters and cans.
Dave
Dave, thanks, being retired and a custom gunsmith, I'm lucky enough to have a full machine shop. However, sometimes it's more efficient to buy mass produced part.
BTW, thanks for the great article, PVC 101, I printed it and put in with my "Good Stuff". I wish I'd read your article first.
Cheers, Curt
I do not drive my C5 hard, so this has convinced me, I need a catch can.
Let me know when and where I can get one.
Secret, I should be able to find out (tomorrow) if I can add to the initial 10 sets. If not, and the four of you guys who expressed interest here are still interested even if we have to wait until we get more people, I will post again in the For Sale section. At least one other C5 guy I know is in, so we may have 5 people signed up so far.
If so, you've convinced me!! Will put it at the top of my mod list!
