I'm undecided.....
Chris
FWIW- I went with a 224/228/115 grind and while the car has gobs of power it shakes at idle and bucks (slightly at light throttle) and stalls occationally after two different professionals have tuned the car on two seperate dynos. All of this would be considered "no problem" by most enthusiasts as the car is scary fast and drives nearly as well as a stocker but,,,,it's not what I want. I'm going with a more conservative cam 214/220/118 and while I know I'll be giving up some horse power, I am expecting the car will idle smooth with no shake. I've also done quite a bit of research and am probably going to install a 25% underdrive pulley to get back some the HP I'm giving up by swapping cams.
In all - You will be VERY HAPPY with the results of modding you car if you do the research and select the components that will complement the way you use your car.
Good luck
Chris
Good luck
i did the same thing to big on the cam / tsp 233/239 600/605 112 lsa it likes to buck like a wild bronco =that & i am also making the move to step down in cam size something like the 02 z06 cam will be just right for me .Being undecided on camshaft selection is very difficult i was just there , best thing to do is get all the info on cams as u can and absorb it .It can be very tiresome .This question also is gonna go back to the mods u have & when u want the power to come in.Street manners are a big deal for me now .
There's a natural sequence to doing mods that , in the long run, saves you money - like
cold air intake, MAF, ported TB . ported intake;
cam, heads, ported oil pump, timming chain, lifters, injectors and even an under pully:
headers, hi-flo cats x pipe , cat backs ;
gears, TC, trani cooler ( it would help if you shared the info on your car in your sig so people will know if it's an auto or M6 )
Z06 sway bars, tunnel plate, trani brace.
wheels and tires
I know you're going to say "I'm not going that far" - but you WILL.You see, horse power is like money and sex - you never have enough.
MODs are addictive so think carefully before you start then either do a bunch of research on this forum and on LS1tech or ,if you have a good tuner in you area, talk over what you would like to accomplish and MOST importantly how much you're willing to spend.
Do I regret my mods? NO, but I wish there was away I could keep them all and get my money back.
wheels and tires
MODs are addictive so think carefully before you start then do a bunch of research.
I'm in the same boat, have a reasonable idea what I want to end up w/ but not sure where to start and the correct order to do them in.
I own a stock 2001 roadster w/ 6 speed and would like to eventually have Z06 handling and power level.
Would a good start be 3.70-4.11 gears, sway bars, and shocks (along w/ new Goodyear F1s of course) ???
THANKS !!!
http://forums.corvetteforum.com/show...ight=ecs+h%2Fc
and this is someone who put it in their car also
http://forums.corvetteforum.com/show...+h%2Fc+results
I sure do miss the ol girl..
as for my 2004 Vette, I put Borla Stingers on it, going to do a air filter system, 373 gears and a torque converter. And I'm telling myself that is all that I'm going to do.....yea, right!
Gohard, or don't go at all!
Good luck and succomb to the modding. Just choose your mods carefully.
Tony M.
