Rough Idle when going into Gear
Old Jan 2, 2007 | 10:12 PM
MannyFresh's Avatar
MannyFresh
Default Rough Idle when going into Gear
I did a search for this already but didn't really find anything. The car vibrates and the rpm's go down when putting the car into Drive or Reverse but once it's in gear it idle's just fine. What could be the problem?
Thanks in advance,
Manny
Old Jan 2, 2007 | 10:24 PM
PDQC5's Avatar
PDQC5
My 98 A4 does the same thing. I thought I read on the forum one time that high mileage spark plugs can cause erratic/low idle conditions. Maybe someone else can confirm if the plugs can cause this.
Old Jan 3, 2007 | 01:18 PM
MannyFresh's Avatar
MannyFresh
Well I changed the spark plugs and wires about a month ago so it can't be that. I'm thinking maybe something with the battery? Alternator? Anyone?
Old Jan 3, 2007 | 01:37 PM
VetteDrmr's Avatar
VetteDrmr
When was the last time you had the tranny fluid flushed? Old or tired tranny fluid can cause all sorts of headaches.
Want to help, but need more info.
Have a good one,
Mike
Old Jan 3, 2007 | 05:21 PM
Bfail's Avatar
Bfail
I have the same problem with my 99' vette.
Old Jan 3, 2007 | 06:08 PM
Todd157k's Avatar
Todd157k
Banned Scam/Spammer
There's been several threads on rough idle. Most of them seem to cure (as did mine) with a good flushing using Sea Foam. Also, check for intake leaks.. usually AFTER the MAF.
Old Jan 3, 2007 | 08:12 PM
tomas721's Avatar
tomas721
Thanks in advance,
Manny
If you have an A4 and this is happening on start-up then wait until the DIC displays "Brake Before Shift" and see if that helps. My guess is that it takes the computer a few seconds to initialize and that message indicates that it's ready to go.
Old Jan 4, 2007 | 07:44 PM
MannyFresh's Avatar
MannyFresh
Cool, thanks for the help guys
To Rough Idle when going into Gear
