Canada Gauge Cluster...
Old Jan 2, 2007 | 11:09 PM
Corvette Don's Avatar
Corvette Don
Default Canada Gauge Cluster...
I have a Canada spec car and was wondering if I could get the USA spec cluster for my car, will it bolt right in w/ no problems and work fine?
Old Jan 3, 2007 | 08:18 AM
BiggieBoy's Avatar
BiggieBoy
St. Jude Donor '06-'07
Yes, you can change clusters w/o any problem...
Old Jan 3, 2007 | 08:21 AM
Corvette Don
Wow, so I wont run into a exta harness or anything? My HUD will still work?? Do I have to get one for a 2000 or will one from 97-04 work? thanks
Old Jan 3, 2007 | 08:31 AM
BiggieBoy's Avatar
BiggieBoy
If you have a HUD get a 2000 or newer cluster. 1997 to early 1999 clusters are not HUD enabled and will not work if you have a HUD. Good luck...
Old Jan 3, 2007 | 08:35 AM
Corvette Don
Thanks a lot, im surprised it will bolt right in a work fine!
Old Jan 3, 2007 | 08:40 AM
BiggieBoy's Avatar
BiggieBoy
Forum member "PaceThis" sells clusters, HUD stuff, etc. Try to check w/ him. I'm sure he will take care of you. He can also reprogram clusters to go along w/ the current mileage of your present cluster..Good luck w/ your project....
Old Jan 3, 2007 | 08:48 AM
Corvette Don
Thanks, I have a guy on here that would like to trade me! Cant beat that, thing is that I have to send him mine to program the milage and I am debating if I want down time with the vette, but then again I dont wat to pass this up
To Canada Gauge Cluster...
