Torque Wrench for Battery???
Old Jan 4, 2007 | 07:31 PM
460HP-YLO-JAKT's Avatar
460HP-YLO-JAKT
Default Torque Wrench for Battery???
What are folks using to torque their batteries to 11 Ft. Lbs.? I have 3/8 drive inch pound totrque wrench wich is too thick. Any help appreciated.
Old Jan 4, 2007 | 07:37 PM
jeanlucpicard's Avatar
jeanlucpicard
I use a battery terminal ratchet (I think they are 8mm or so) that I goit at Sears and just nut the two bolts down snug - no torque.
Old Jan 4, 2007 | 08:03 PM
GRB's Avatar
GRB
Torque them in 1 pound increments or you'll end up with warped terminals. Also, no air guns whatsoever!! You can thank me later.
Old Jan 4, 2007 | 08:47 PM
RedLS1GTO's Avatar
RedLS1GTO
Use a spring scale. Hook it onto the and of the wrench. Divide 11 by the length of the wrench (in feet) from the center of the bolt to where the scale is hooked eg. 6" = .5. Tighten and check by pulling on the scale perpendicular to the wrench until the scale reads that number. Voila 11 ft/lbs.
Is this post for real??
Old Jan 4, 2007 | 10:13 PM
GRB's Avatar
GRB
I only do it that way when I'm in a hurry.
Old Jan 4, 2007 | 10:33 PM
RedLS1GTO's Avatar
RedLS1GTO
A $100k engineering degree and apparently all I learned was how to use it be a smartass. D'oh!
Old Jan 4, 2007 | 10:45 PM
Gohard777's Avatar
Gohard777
Where can I get these thingamabobs, they look great for fishin...bob.
Old Jan 4, 2007 | 10:52 PM
GRB's Avatar
GRB
Fishing??? Those hooks look a little dull! You might want to rethink that!
Old Jan 5, 2007 | 02:46 AM
TheDVS1's Avatar
TheDVS1
I use a 1/4" drive and just snug-em down enough so that the terminals don't move. That's all ya' need.
Old Jan 5, 2007 | 09:06 AM
TEXHAWK0's Avatar
TEXHAWK0
I can pull 11 ft-lbs just using wrist action on a 1/4" drive ratchet, so that is all I use too.
Old Jan 5, 2007 | 10:22 AM
GRB's Avatar
GRB
You guys are making a horrible mistake! That battery is going to totally warped within 3,000 miles!
Old Jan 5, 2007 | 12:46 PM
oldschoolvette's Avatar
oldschoolvette
I use an 8 mm battery wrench I got at Autozone. It has a built in release and if you exceed 12 ft-lbs it free-wheels. I find it most helpful and I have never warped a battery in over tweenty years.
Old Jan 5, 2007 | 01:57 PM
94legaleagle's Avatar
94legaleagle
So THAT'S what Snap on has been doing with those 8mm wrenches that I keep returning to them - every time I try and use the 8mm Snap on wrench to torque my lug nuts, the Da** thing strips out
Old Jan 5, 2007 | 02:51 PM
GRB's Avatar
GRB
12 ft-lbs? You sir, are playing with fire. However, I do admire your bravery.
Old Jan 5, 2007 | 06:02 PM
Oldvetter's Avatar
Oldvetter
I torque first to 5 ft-lbs, then 8 ft-lbs, then 11 ft-lbs. I had a warped battery once, never again!
Old Jan 5, 2007 | 07:41 PM
Ol'55's Avatar
Ol'55
From: Southern New Jersey, The wet part at the bottom
St. Jude Donor '08-'09-'10
Old Jan 5, 2007 | 10:41 PM
Gohard777's Avatar
Gohard777
Default something is warped all right..
I'm afraid to tie my shoes now, where's my slippers.....
Old Jan 6, 2007 | 12:33 AM
easyasone2three's Avatar
easyasone2three
Please!! Just Kill Me!!
To Torque Wrench for Battery???
