Tire size and active handling?
Old Jan 6, 2007 | 04:13 PM
7LitreC5's Avatar
7LitreC5
Default Tire size and active handling?
I did some searching on this and could not find quite the answer that I was looking for. I have a 2002 coupe.
I have an opportunity to trade my current wheels/tires (265/35-18 and 295/35-18) for another set of wheels/tires (275/35-18 and 335/30-18).
The diameter of the new tires are 25.7" front and 25.9". This differs quite a bit from the stock size and differs a fair amount from what I have now. Will the front/rear difference of only .2" cause active handling problems when the stock difference was 1.1"?
Old Jan 6, 2007 | 04:23 PM
robvuk's Avatar
robvuk
It might work but it will be hypersensitive on the traction control side.
Old Jan 6, 2007 | 04:38 PM
John Shiels's Avatar
John Shiels
From: Buy USA products! Check the label! Employ Americans
no problem at all I run same front and rear on the slicks 25.5 and also run 275x17 and 315x18
Old Jan 6, 2007 | 05:20 PM
7LitreC5's Avatar
7LitreC5
Is the AH on the 99 and earlier cars any more or less sensitive than the AH on the later cars?
Old Jan 6, 2007 | 07:45 PM
John Shiels
you should not have a problem on any C5 doing that.
Old Jan 6, 2007 | 07:52 PM
7LitreC5's Avatar
7LitreC5
Ok, thanks!
Old Jan 6, 2007 | 08:04 PM
rws.1's Avatar
rws.1
It becomes an issue when the fronts are larger diameter than the rears and the rear rpm is higher than the front. the computer interprets that to mean the rear wheels have lost traction and are spinning.
With only .2 inch difference, you will not need very much rear wheel slippage to kick in traction control...
Old Jan 6, 2007 | 08:14 PM
7LitreC5's Avatar
7LitreC5
That makes perfect sense! Thanks.
Old Jan 6, 2007 | 09:57 PM
01C5fan's Avatar
01C5fan
Those sizes are what I run on the street. No problem at all.
To Tire size and active handling?
