97 Won't Start
Old Jan 7, 2007 | 11:18 AM
77BlueL82's Avatar
77BlueL82
Default 97 Won't Start
Went to start the car and all I got was a click.
I put the charger on and still no start just a click.
Radio, lights all look ok.
The service manual only has info if there is no click.
Anything I should check to confirm if the starter needs to be replaced?
Thanks in advance.
Old Jan 7, 2007 | 02:24 PM
108C6's Avatar
108C6
ck. your batt. cables remove them and clean also make sure your batt. is charged if the batt. is an delco they leak at the batt. terminals and cause many problems if cables are green and dirty from the leaking batt. clean them with water and baking soda and replace the batt.
Old Jan 7, 2007 | 03:30 PM
Corvette Don's Avatar
Corvette Don
Check connections on the batt
Old Jan 7, 2007 | 10:15 PM
77BlueL82's Avatar
77BlueL82
Default Thanks
My gut feeling is that it is the starter. I'm going to have to get a volt meter and check the battery.
Old Jan 7, 2007 | 10:26 PM
corvettedoug's Avatar
corvettedoug
I would check the simple stuff before going to the starter.
-Make sure the battery is charged
-Cables are tight at battery and grounds are clean.
- If you have a 6 speed you should see the following when you turn the key.
1) push clutch in and turn key, should hear theft deterrant relay click in floorboard of passenger side.
2) hold the key to the start position and release then push clutch pedal in, you should hear the theft deterrant relay click on and off each time you fully engage/disengage the clutch pedal - this is showing that the clutch pedal sensor is working
If all above works as described it is probably connections at battery, starter or starter itself.
I know how frusterating it can be to diagnose something like this, been there done that.
Old Jan 8, 2007 | 12:16 PM
dalascwbyfan's Avatar
dalascwbyfan
6th Gear
Default RE:97 not starting
My 97 just came out of the shop last week . It was doing the same thing. It needed a body control module. Starts like a champ now!
Old Jan 8, 2007 | 12:24 PM
77BlueL82's Avatar
77BlueL82
Default Bcm?
Thanks for the info Dalas Cowboy Fan. I feel your pain, I'm a Giant Fan.
Do you have a Auto or Manual Trans?
Old Jan 8, 2007 | 09:38 PM
phils C5 vette's Avatar
phils C5 vette
St. Jude Donor '12-'13-'14
clutch safety switch on the floor board if you have s MN6
Old Jan 8, 2007 | 09:54 PM
77BlueL82's Avatar
77BlueL82
Default Safety switch...
I have an auto.
The starter is clicking louder than ever after I charged the battery. I thing I'm going the starter route.
To 97 Won't Start
