Dyno Tune vs Street Tune
Old Jan 7, 2007 | 10:16 PM
NemesisC5's Avatar
NemesisC5
Default Dyno Tune vs Street Tune
As far as I know many or most Tuners do their Tuning on Dynos with some of them never tuning the car on the street. With the cost of a tune around $400 give or take and a retune around $100-150, I would think the car should receive street tuning and use the dyno for mostly WOT maximum HP numbers. It seems to me to get the best all-around driveability, throttle response, and idle quality the car would require some data logging while street driving. I am obviously no expert, that is why I am asking this question. Am I wrong in my assumptions? Can a modified car be Dyno Tuned only and still achieve best results? Thanks in Advance for Your Opinions
Scotty
Old Jan 7, 2007 | 10:37 PM
Corvette-Chris's Avatar
Corvette-Chris
St. Jude Donor '08
Old Jan 7, 2007 | 11:42 PM
thehammer69's Avatar
thehammer69
Scotty
I personally believe street tuning is the optimum tuning and dyno tuning should be used for maximizing horsepower which doesn't always lead to the best drivability. Plus, it's hard to do part throttle stuff on a dyno unless you have some form of load control dyno. Quite frankly, not many shops invest in a load control dyno.
Hammer
Old Jan 7, 2007 | 11:47 PM
Jeff @ TPE's Avatar
0Jeff @ TPE
Former Vendor
St. Jude Donor '06 & '12
Its all dependant on the dyno. If the shop has the capabilities to load the car and perform partial throttle tuning, then in all actuality you can tune a car better on the dyno then on the street.
Why?? for the most part inconsistancies in traction.
On the other hand, if you dont have a controlable load dyno, then street tuning is the ONLY way to go.
CraZee ZO6's Avatar
CraZee ZO6
Both together is best
Old Jan 7, 2007 | 11:50 PM
Redline Motorsports's Avatar
Redline Motorsports
Thats why we bought a load controlled dyno! We actually will do a combination depending on the setup and type of car. The only real area that benefits slighty is low speed transitions. Dyno tuning WOT on the street is one unsafe and will really yield no better results. If you look at timing and fuel tables they are relative to load and rpm. At any given load/rpm a specific value is commanded. The car doesn't know if its on the street or on a chassis dyno. For WOT we have found that leaner AFR's that make better dyno numbers, run better at the track running a bit richer.
With EFI Live's Road Runner PCM (real time tuning) and a load control dyno, you can really dial a car in under just about every possible load/rpm condition. Also, trying to tune a 600+ RWHP car on the street is a accident waiting to happen!
I always will test drive the car after dyno tuning for any final things that may need to be addressed with respect to drivability.
Old Jan 8, 2007 | 12:15 AM
C_Williams@RPM's Avatar
0C_Williams@RPM
Former Vendor
Yes, you should expect that a tuner do both drivability and dyno tuning and that being stated, the term “street tuning” can, to a high degree accomplish both aspects.
However, bear in mind that WOT tuning requires that there is enough real estate to manage to navigate those high speed, final drive ratio data logging and calibration runs.
The better solution is to use a load control dyno to properly map the fuel and timing cells under every conceivable load condition, all the while measuring success of each change and thereby optimizing the calibration for both performance and the ultimate in drivability.
Old Jan 8, 2007 | 08:43 AM
Billdog350's Avatar
Billdog350
As a side note from a "self tuner", I have logged and adjusted my part throttle drivability, and then dialed in my WOT using a wideband before heading to the dyno. As some of the tuners have noted above, it becomes quite difficult to tune high rpm in 4th gear or above because you're doing 130+mph with stock gearing! You end up grabbing a few data points from a lower gear(2nd) at high rpm and interpolating the results inbetween for tuning. I've used this method for all of my personal vehicles that I've tuned and it ended up being only a few points off on the dyno (12.3 vs 12.5 or whatever I was aiming for). Street tunes can be used to get you in the right direction, but dynos are the safest option for full WOT tuning.
Old Jan 8, 2007 | 09:17 AM
cmb396's Avatar
cmb396
CI 7-8-9-10 Veteran
What about dyno tunes for those of us that are using a Vararam intake?? This intake is designed to work most efficiently at higher speeds. That being said, is a dyno tune good for a vararam? I know the fans that are used are not nearly the same amount of air intake as going 70+ down the road!! Put your hand in front of one of those fans, then stick your hand out the window at 70, you all know there's a difference!! Should I have my dyno tuned H/C/nitroused Z06 retuned with a street tune??
Old Jan 8, 2007 | 11:36 AM
Billdog350's Avatar
Billdog350
I have a vararam and I checked my wideband "at speed" vs the dyno. There wasn't a huge difference between the two readings. Most LS1's I have seen don't make a big difference if you're a couple points off (12.5 vs 12.7) on the AFR anyway.
Old Jan 8, 2007 | 12:34 PM
Redline Motorsports
The MAF can deal with some of those increases as the MAF is the dominate measure device over 4000 rpms. The other nice thing, as Charley noted, is that you can measure your gains on a chassis dyno!
Unfortunately we can't duplicate a 100 mph road test with respect to the overall airflow which is why I at times will tune a tad bit richer on the big end from the dyno results. Again this has proven itself at the track as a good dyno adjustment.
Old Jan 8, 2007 | 03:03 PM
jbauch357's Avatar
jbauch357
We spent a couple hours road tuning mine, and will go to the final tune on a dyno in two weeks. $350 for the tuning plus dyno time, it'll run me approx $450 in the end.
Old Jan 8, 2007 | 04:32 PM
Dan_the_C5_Man's Avatar
Dan_the_C5_Man
You can get a pretty dyno graph / tune in less than 20 mins., but using the shortcut method (ultimately "wrong") you have done nothing to correct the Volumetric Efficiency tables (they along with the MAF and other sensors affect part-throttle A/F mixture) that need adjustment due to the addition of a cam, heads, headers, etc.
The ultimate is to mount a W/B sensor, perform on the road real-time logging and tuning until the VE table is correct, then go back and adjust the PE table (WOT / what you see on a dyno sheet) for maximum power.
Old Jan 8, 2007 | 06:08 PM
NemesisC5's Avatar
NemesisC5
I have seen some tuners take the shortcut method and do the "20 minute Dynojet tune" with the W/B sensor in the tailpipe. IMHO, I believe this approach gives the customer less than what is best for their car and takes away from the crisp feel of a sharp tune under part throttle driving conditions. The bitterness of poor quality lasts far longer than the sweet taste of a low price
Scotty
To Dyno Tune vs Street Tune
By Michael S. Palmer | 2026-06-03 09:39:05
