What kind of insulation?
There is Dynomat Extreme, FatMat, Crazy Cowboy (CF vendor) and kool-mat (very expensive).
I used kool-mat because I don't plan on selling my car ever. Price tage was around $1,500 bucks. It was a pain in the a$$ to install.
Cheapest way would be Dynomat type of product (generic) and a tunnel plate from elite engineering, IMHO.
Koolmat install info
http://www.vetteweb.com/tech/vet_050...all/index.html
St. Jude Donor '06
use cowboys kit for heat, adn use a closed cell foam layer to help cut on sound. you can get the closed cell foam at elemental designs really cheap and they ofter a forum discount as well if you call them. The mat deadner is really more for vibration than noise.
St. Jude Donor '06
check this out... http://www.quietcar.net/
here is edead on my doors
and on the rest
but the liquid stuff is more for vibration noises than heat and road noise. for road noise you would want a closed cell product.
I used the kit from exotic vette. http://www.exoticvette.com/insulation%20c5.htm
worked great.....very light stuff full kit weighs maybe 3 pounds.
Dynamat is a good solution of you are only going to use a little or don't care about the weight addition. I used some of it to deaden my shifter and insulate around the center console - but that is as much as I am willing to add...
Dynamat - .68 lb/ft
DynaPad - 1.09 lb/ft
Total square footage of C5 kit (per the spec sheet on the DynaMat site):
Dynamat - 84 sq ft
DynaPad - 156 sq ft
Total weight for C5 kit - 227lbs
No way in hell am I going to add another ~230 lbs to my car just to reduce a little road noise, but it's your car do what ya want...
Dynamat - .68 lb/ft
Dynamat - 84 sq ft
DynaPad - 156 sq ft
