Lug Nut Torque
Old Oct 1, 2001 | 10:46 AM
Torch 97's Avatar
Torch 97
Default Lug Nut Torque
I had my car into the dealer to have the emergency brake adjusted. They could not resist taking off the rear wheels. I asked them if they used a torque wrench to tighten and they did not. They say there air wrenches are set at the correct level. I thought I should check. What is the correct level for lug nuts to be torqued too. Thanks.
Old Oct 1, 2001 | 11:06 AM
C6~Missle's Avatar
C6~Missle
Default Re: Lug Nut Torque (Torch 97)
I believe it 100 ft lbs.
:flag
Old Oct 1, 2001 | 12:01 PM
Ranger's Avatar
Ranger
By all means, loosen the lug nuts and retorque them. The favored approach is a three step tightening at 50 ft-lbs done in a star pattern. then 75 ft-lbs and then 100 ft-lbs. This ensures even torque all-round and greatly reduces the chance of warped rotors.
Ranger
Old Oct 1, 2001 | 01:09 PM
carpe dm's Avatar
carpe dm
Rangers right. I would also be sure that the face of the rotor hub, which will come in contact with the wheel, is clean and free from rust and debris. Sometimes they just pop them back on...... :rolleyes:
Old Oct 1, 2001 | 01:23 PM
bruce1's Avatar
bruce1
Default Re: Lug Nut Torque (Ranger)
Ranger is right.
100 lbs.
:chevy
Old Oct 1, 2001 | 02:18 PM
Torch 97's Avatar
Torch 97
Default Re: Lug Nut Torque (bruce1)
Thanks for the help, just the information I needed.
Old Oct 1, 2001 | 03:00 PM
DAB's Avatar
DAB
Cruise-In I Veteran
Cruise-In II Veteran
St. Jude Donor '10
of course ranger is correct, who do you think did his front wheels last week? he learned that from me.
Old Oct 2, 2001 | 08:59 PM
Ranger's Avatar
Ranger
Default Re: Lug Nut Torque (DAB)
Bless his heart. DAB alway brings a full kit of tools to our club's shop night. Thanks again, DAB.
Ranger
Old Oct 2, 2001 | 09:07 PM
vette-crazy's Avatar
vette-crazy
Ranger is the man! I never let an air wrench near my wheels. Do like I did and find a good little shop that will take the time to change/rotate/balance your wheels/tires w/o using the air wrenches. Those things are bad news.
To Lug Nut Torque
