Steering postition sensor install
Old Jan 10, 2007 | 07:32 PM
Ducati749's Avatar
Ducati749
Default Steering postition sensor install
Well I've been following the directions on this web site: http://www.ddisoftware.com/c5-procs/ Only thing is this is for a 1999, mines and 02. Everything went well until i went to pull the steering wheel out. It seems the telescoping wheel hardware(i think) is making it impossible to remove by just an 1/8.
Old Jan 10, 2007 | 07:57 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Did you put the steering wheel all the way in towards the dash before you started ?
Old Jan 10, 2007 | 08:15 PM
Ducati749's Avatar
Ducati749
shoot no i didn't...Well i couldn't my telescoping wheel no longer works, but it seems like it wouldn't make a difference...
Old Jan 10, 2007 | 08:49 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
What kind of problem are you having. Since the whole steering column is suppose to come out, I can't see how it would get stuck.
I have shop manual's for 2001 / 2002 vettes if you could take a picture of problem and post maybe somebody could help.
Old Jan 10, 2007 | 09:46 PM
FRCTony's Avatar
FRCTony
If you haven't, take the part with the white foam (knee pad) out.
Old Jan 10, 2007 | 11:06 PM
Ducati749's Avatar
Ducati749
Sorry these pics aren't so great. The circled tab in the last picture is what seems to be causing the snag. I tried to unbolt the damn thing but it's welded to the column.
Old Jan 11, 2007 | 04:22 AM
Ducati749's Avatar
Ducati749
After taking off all the nuts. The column drops and the tab hits the support bar below it before the upper bolts can clear.
Old Jan 11, 2007 | 05:24 AM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
According to the service manual you are suppose to
1.) Remove the the upper steering column bracket nuts from the upper reinforcement assembly.
2.) Slide the steering column off of the intermediate shaft.
3.) Remove the steering wheel from the vehicle.
Rotate the steering column clockwise as the bottom of the steering column reaches the reinforcement assembly. This will allow the telescoping steering column motor and the steering wheel position sensor room to clear the instrument panel brace.
Old Jan 12, 2007 | 09:00 AM
Ducati749's Avatar
Ducati749
good stuff ill give this a shot as soon as i find the time. Thanks
Old Jan 24, 2007 | 10:52 PM
Ducati749's Avatar
Ducati749
hmmm didn't seem to do the trick...any ideas?
Old Jan 25, 2007 | 12:10 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
My sensor failed a few years ago on my '99. Rather than worry about setting off the airbag, I elected to pay the dealer to replace it for me. Labor was $165 at that time for the whole job. No mistakes and no problems.
Old Jan 25, 2007 | 03:05 AM
Ducati749's Avatar
Ducati749
ill keep that in mind for next time....good price
Old Jan 29, 2007 | 04:08 PM
Ducati749's Avatar
Ducati749
Thanks everyone, with all the info i found nothing wrong with my procedure. So I gave it a little man power and it popped right out... It seems it was a tight fit due to the tab... WOA be careful not to pop-off the rubber grommet that's fitted to the firewall. It was difficult for me to put back.(there is probably a trick) When I went to put the steering wheel back in, I had my brother keep back-pressure on the rubber grommet
To Steering postition sensor install
