Why is my DIC cold?
Old Jan 12, 2007 | 12:29 PM
kvozel's Avatar
kvozel
From: Centerville OH "If we weren't all crazy we would go insane"
CI 3-4-5-6-7 & 9 Veteran
St. Jude Donor '08
Default Why is my DIC cold?
No, this isn't an Off Topic post
Had the car out the other day when we went to dinner. After dinner, started the car and got "Active Handling Warming Up" on the DIC. Obviously not that many letters, and then about 2 seconds later, "Warmed UP" was displayed. After 2 'vettes over 7 years, never saw that.
Any ideas?
Old Jan 12, 2007 | 02:19 PM
LUV-Vettes's Avatar
LUV-Vettes
Cruising
Default DIC message
My '02 has done the same thing several times without any noticable problems.
Old Jan 12, 2007 | 02:20 PM
My '99 did that too - no problems noticed with the system working. The owners manual may tell you that there is nothing to worry about.
Old Jan 12, 2007 | 02:34 PM
CSC5's Avatar
CSC5
From: Yeah, well, you know, that's just, like, your opinion, man.
I get that all the time. I think I recall someone saying that it comes up if you get tire slippage within a certain amount of time after start-up. Immediately after leaving my driveway, I'm driving a curvy street up a hill, which is when I see it.
Old Jan 12, 2007 | 02:35 PM
C5 ChemE's Avatar
C5 ChemE
I get it too occassionally- perfectly normal. Seems to go away as soon as you hit 25mph
Old Jan 12, 2007 | 04:38 PM
DPG's Avatar
DPG
St. Jude Donor '06
happens to me about once a month
it happens when you start the car and start driving and what the car is looking for is you driving staight for a couple feet to get the traction control setting right. My neighbor hood has a lot of turns with in a short distance till the main street and i will get this until i hit the main street. then after about 50-100ft of straight driving it goes away
Old Jan 12, 2007 | 05:04 PM
RichieRichZ06's Avatar
RichieRichZ06
From: Supporting the Corvette Community at Abel Chevrolet in Rio Vista, CA 707-374-6317 Ext.123
St. Jude Donor '08
It is due to the steering wheel position sensor recalibrating after startup.
Here is a brief description of the system from GM Service Info.
Traction Control and Active Handling System Indicator(s)
ACT HNDLG-WARMING UP
The IPC illuminates the ACT HNDLG-WARMING UP indicator in the message center when the following occurs:
The active handling option needs to be present in order for this indicator to appear. The EBCM detects that the engine is on and the vehicle speed is at 6 mph (10 km/h) or below. The IPC receives a class 2 message from the EBCM. The DIC will display this message for 3.5 seconds and then turn off. A chime will sound will this message is displayed.
When this message is displayed the traction control and active handling system indicator turns on.
ACTIVE HANDLING
The active handling option needs to be present in order for this indicator to appear. The IPC illuminates the ACTIVE HANDLING indicator in the message center when the EBCM detects that the vehicle stability enhancement system is on. The IPC receives a class 2 message from the EBCM. The DIC will display this message for 3.5 seconds and then turn off.
Old Jan 12, 2007 | 08:21 PM
BanditDude's Avatar
BanditDude
The first time that I noticed this was at an auto-x event. I tried placing it in competitive mode on startup and got this notice after completing the course. Apparently, I couldn't drive long enough in a straight line to engage the A/H before doing the course.
Old Jan 12, 2007 | 10:51 PM
cruisemon's Avatar
cruisemon
Originally Posted by kvozel
Why is my DIC cold?
I'm tellin' ya we gotta find another acronym for that thing.
Charlie
Old Jan 12, 2007 | 10:56 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
ACTIVE HANDLING
Now,,,,,,,,,,,,,,thats the correct answer!!!! COMPLETELY NORNAL!
Old Jan 12, 2007 | 11:15 PM
Ty.'s Avatar
Ty.
Charlie
HAHAHAHAHAHA
Old Jan 13, 2007 | 12:53 AM
Choreo's Avatar
Choreo
I only get this when I go to Olive Garden for dinner, but get it there 80% of the time because is takes several twists and turns to get out of their parking lot. (sometimes out of their front door as well).
Old Jan 13, 2007 | 09:48 AM
kvozel's Avatar
kvozel
St. Jude Donor '08
ACTIVE HANDLING
Excellent
Thanks.
Old Jan 13, 2007 | 10:18 AM
cruisemon's Avatar
cruisemon
Why is my DIC cold
Can't stand it any longer.
YOUR FLY IS UNZIPPED.
Charlie
Old Jan 13, 2007 | 11:03 AM
kvozel's Avatar
kvozel
St. Jude Donor '08
Charlie
Old Jan 13, 2007 | 11:55 AM
The Spark's Avatar
The Spark
Charlie
Beat me to it.
I was going to say put it back in your pants OR go to the bathroom inside instead of in the yard.
Old Jan 13, 2007 | 11:57 AM
RedLS1GTO's Avatar
RedLS1GTO
What's wrong with going in the yard?
To Why is my DIC cold?
Old Jan 13, 2007 | 04:38 PM
Bluefire's Avatar
Bluefire
Maybe your grip is too tight and you cut off it's blood supply?
Old Jan 13, 2007 | 04:59 PM
cruisemon's Avatar
cruisemon
I KNEW I shouldn't have let the devil get hold of me and put up the thing about the fly. It's all downhill from here.
IBTL
Charlie
Old Apr 25, 2011 | 10:25 AM
mikesvette1's Avatar
mikesvette1
thanks for all the info, i just got an 2001 and was curious about the same thing, thought something was broke. it usaually does it driving driving down my driveway which is gravel and by the time i get on the road it goes away, thankyou so much
