A key problem
Old Jan 12, 2007 | 11:25 PM
87bob's Avatar
87bob
Veteran: Coast Guard
Default A key problem
Sorry yes this posted in the general section. It is something I have never seen any where in the C-5 forum so I'm looking for all the help I can get.
Here is my problem. I have a 99 and I had two keys. One would work no matter which way you inserted it in the ignition. The other would only work one way. Thinking it was a bad key I ordered another blank at 50.00 bucks.
I took the good key with me when I went to pick up the new blank. They cut the new key from the good old one but it acts just the other bad one. The new one works only one way. Anyone got any ideas I am totally puzzled?
Old Jan 13, 2007 | 08:45 AM
dwarmenzerk's Avatar
dwarmenzerk
hmm, interesting, maybe call the dealership, and ask why dont make them pay for it..
Old Jan 13, 2007 | 03:40 PM
87bob's Avatar
87bob
I intend to.
Old Jan 13, 2007 | 05:18 PM
zo6vetteman2003's Avatar
zo6vetteman2003
Sounds like it could be the ignition is worn. Inside the cylinder are two contacts that read the key's resistor pellet. When these get worn, they tend not to read the keys resistor pellet or give an intermittent reading.
Old Jan 14, 2007 | 09:24 AM
87bob's Avatar
87bob
The car has only about 35,000 miles on it. Do you know how diffucult it is to replace the switch?
Old Jan 14, 2007 | 11:44 AM
zo6vetteman2003
Mine went at approx. the same mileage. The dealer wants $90.00 for the new ignition cylinder. You can also fix it for under $10.00 by bypassing the VATS is what I did. This may be what your problem is. If you want more info. on the bypass, let me know.
Old Jan 14, 2007 | 10:33 PM
87bob's Avatar
87bob
Sure I'd like to by pass the Vatts it's just a PITS as far as I'm concerned. How did you do it?
Old Jan 15, 2007 | 09:19 AM
zo6vetteman2003
First you need an ohm meter to read your key's resistor pellet. For example let's just say your key's resistor reads 7500ohm.
Go to radio shack and buy a 10K (10,000ohm) potentiometer. The potentiometer is adjustable and you can dial in the 7500ohm using the ohm meter. In the back of the ignition there is a plug. The plug has 2 wires, a white wire with a black stripe, and a purple wire with a white stripe. What you need to do is solder two wire leads onto the potentiometer that read 7500ohm across them. These two wire leads you will insert into the back of the plug, one where the white wire with a black stripe is, and one where the purple wire with a white stripe is.
This will give you a 7500ohm reading to your VATS at all times. Put it all back together leaving the potentiometer set for 7500ohm plugged into the back of the ignition. You should be able to use both of your keys in either direction to start the car without any problems from then on.
Old Jan 15, 2007 | 09:59 AM
BanditSRT's Avatar
BanditSRT
I had a similar thing happen to me. It turned out that the key wasn't cut exactly like the old one. I made the dealer pay buy me a new blank and re-cut it. Now all my keys work the same.
To A key problem
