Parking Brake
Old Jan 13, 2007 | 12:58 PM
mike85mph's Avatar
mike85mph
Default Parking Brake
Is there a way to adjust the praking brake on a C5? Mine just doesn't hold very well - especially on a hill. I have a 99 hardtop 6-speed coupe and it just won't hold very well on a hill.
Old Jan 13, 2007 | 04:38 PM
Last C5's Avatar
Last C5
Short answer - yes. The parking brakes have an adjustment system similar to a set of drum brakes. Remove the rear rotor (WITH THE PARKING BRAKE HANDLE OFF) and you can access the adjustment wheel.
Old Jan 13, 2007 | 05:19 PM
Patches's Avatar
Patches
Gotta' take the caliper, caliper bracket and rotor off but it gives you access to the e-brake adjuster. Be careful not to allow the spring that holds the shoes on to fall off, otherwise you're in for a PITA reinstall of that spring.
Old Jan 13, 2007 | 05:23 PM
LoneStarFRC's Avatar
LoneStarFRC
When properly set, parking brake handle only needs 11 clicks to fully set the parking brakes. That puts the handle in approx. a 45 degree angle.
Old Jan 13, 2007 | 06:12 PM
Burgie's Avatar
Burgie
I adjusted mine by coasting backward slowly and pulling the e-brake handle up stopping the car. Repeated this several times and now the brake holds on a hill. May work for yours-
Old Jan 13, 2007 | 06:23 PM
mike85mph's Avatar
mike85mph
Default Thanks!
I will give the coasting backward method a try first and if that doesn't work we'll go to removing the caliper and rotor and rotating the adjuster wheel. Thanks guys.
Old Jan 14, 2007 | 03:28 PM
bighank's Avatar
bighank
Default Parking Brake Adjust
Disconnect the P-Brake cable at the wheel b4 removing the rear rotors.
Adjust star wheels till just a little drag is present installing and removiong the rotors. Reattach the cables at the wheels and THEN try going backwards and using the P-Brake lever.
BTW I DID knock one of the springs off that hold the P-brake shoes on.
Took me about 3 hours to get it back on. Finally used a spring hook thru the hole in the hub after latching it on one side and then gently sliding it over the other latch rasied metal which holds the spring at the end of the spring. BIGHANK
Old Jan 14, 2007 | 04:37 PM
Oldvetter's Avatar
Oldvetter
do about 10 mph in reverse and pull up the brake. Do three times. This will adjust the cable. If your parking brake drums are too gone, you need to adjust them as above posters suggested.
Old Jan 15, 2007 | 02:28 PM
slayer6x6's Avatar
slayer6x6
My star wheels were out a good 20 clicks per side!
Old Jan 27, 2007 | 01:06 PM
BWP 5P's Avatar
BWP 5P
Veteran: Marine Corps
St. Jude Contributor
That is NO $hit......I fought one last night for over an hour. Has to be something better than that?!?!?!
Old Jan 27, 2007 | 02:41 PM
bighank's Avatar
bighank
Default Parking brake
GM Manual says install the spring... like you are clairvoyant or something
After you do it ONCE you can do it again. BIGHANK
Old Jan 27, 2007 | 11:58 PM
Bill Dearborn's Avatar
Bill Dearborn
First thing to do is pull up on the parking brake handle 3 times in succession. Cycling the park brake lever three times is the method used to obtain proper park brake cable tension. If that doesn't work then pull the rotor.
Bill
Old Jan 30, 2007 | 12:08 PM
bighank's Avatar
bighank
Default parking brake
I tried pulling my handle for about 4 years. NO CHANGE. When I finally did the rear brakes I clicked the starwheels over 20 clicks till the shoes just rubbed the rotors and NOW the parking brake WORKS. From here maybe backing up and pulling the p b handle will keep them tight? Maybe or maybe not. BIGHANK
To Parking Brake
