Clutch removal help - C5
Old Jan 16, 2007 | 09:20 PM
ridenmyvette's Avatar
ridenmyvette
1st Gear
Default Clutch removal help - C5
Hi Guys. I am in the middle of removing the clutch in my 2000 coupe. I am at the step in the corvette service manual from chevy where is says to use tool j-36221, depress the white circular release ring on the actuator cylinder hose and simultaneously pull lightly on the master cylinder hose to disconnect.
Now my problem is I don't have that tool. I can get one but I am sure its an order piece. How much does it cost? And is there another tool that can do the job or a different way to disconnect it. Thanks
Old Jan 16, 2007 | 09:28 PM
SnowyATX's Avatar
SnowyATX
I feel for ya. I've removed the front suspension, engine, rear-end, transmission etc. That damn connector has pissed me off just about more than anything else. I want to say that the newer years are easier than mine was. I was replacing my slave so I just cut the damn hose with a lock cutter. Do some searches and you may find more details.
Good luck
Old Jan 16, 2007 | 10:05 PM
Jeffs FRC's Avatar
Jeffs FRC
I used an AC and fuel line disconnect tool kit. You can get these at any auto store.
This was the hardest part of the clutch install for me. Took about an hour and a half, 3 beers, and a whole lot of swearing.
Old Jan 16, 2007 | 10:32 PM
happa's Avatar
happa
also its a GREAT investment to buy the speed bleeder form L.A.P.D. Did a clutch swap many of times and I finally put the speed bleeder in and man it cut the time in half and less pain in the a$$ to bleed. Good Luck!
Old Jan 16, 2007 | 10:47 PM
mitymikec's Avatar
mitymikec
I was able to do it with my fingers but that sme..U could also use a pair of channel lock pliers but be very careful not to break the white ring bro...It's not hard at all...
blown alcohol's Avatar
blown alcohol
Push the hose in coming from the master cylinder, then use a smaller flat blade screw driver and push in one side of the white ring. Use your finger to hold it in then use the screw driver again on the exact opposite side that is pushed in. Pull and its out. The key is to keep the master cylinder hose pushed in while pushing the release ring in. I work for a Chevy dealer and done tons of clutches and never used the J tool once.
Old Jan 17, 2007 | 07:35 AM
3X2's Avatar
3X2
I use a OTC 7910. It's available at auto parts stores for a couple of dollars.
Mark
Old Jan 17, 2007 | 09:10 AM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
I got the release tool from the SnapOn truck
Old Jan 17, 2007 | 10:26 AM
Billdog350's Avatar
Billdog350
Did this on my clutch, worked perfectly.
Old Jan 17, 2007 | 11:44 AM
vettenuts's Avatar
vettenuts
Got a number? I am readying a Snap-On order so maybe I will add it in.
Old Jan 17, 2007 | 05:46 PM
SteveDoten's Avatar
SteveDoten
I think it's the one from post #7
it's a bit flimsy, but does work; I've heard napa carries a similar tool, I wouldn't buy the otc unit again, $30 piece of sheet metal
Old Jan 17, 2007 | 06:55 PM
hisvett's Avatar
hisvett
St. Jude Donor '14-'15
I made mine out of an old 5/8" open end wrench. Just a bit of grinding and wiz-bang! Works just like a store bought tool.
Old Jan 18, 2007 | 08:19 AM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
I use a long pair of needle nose pliers with the bent end, once you reach up and push in on the collar it will stay, it's actually harder to reassemble the hose then it is to take it apart.
Old Jan 18, 2007 | 09:29 AM
Casem1's Avatar
Casem1
Sounds like a few of us are doing the same thing right now. This is actually the step I left at last night. My torque tube has been pulled a few inches and this is all that is left.
I haven't tried anything yet, but I think I will go try now with some screwdrivers before I go buy yet another tool.
Old Jan 18, 2007 | 09:52 AM
95BlueBomber's Avatar
95BlueBomber
Does anyone make an aftermarket piece to replace this line? That would be nice to just have a regular line in there minus this contrary thing.
Old Jan 18, 2007 | 10:43 AM
Casem1's Avatar
Casem1
Going to buy a tool................
I think I may have mangled that little plastic thing. Seriously! WTF??? I can't understand how such a queer connector was ever approved. I work in an industrial setting, I deal with quick connects that see thousands of pounds of pressure that are simple, ALL METAL connectors that you can undo with one hand.
Maybe if I could get the junk LG Streets out of the way (more on that and pictures to be posted later in a "LG Sucks" thread) then I would have more luck.
Old Jan 18, 2007 | 11:05 AM
95BlueBomber
Sometimes the connector will be unlatched but if you take some pliers to both pieces and pull apart it will let go. I had this just last week, took some needle nose with the round ends and it pulled right apart. I started by using screw drivers to work the plastic collar in then pulled it apart.
To Clutch removal help - C5
Old Jan 18, 2007 | 02:29 PM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
Definitely take the header out, when I do a clutch I remove headers.
Old Jan 18, 2007 | 03:34 PM
ericdwong's Avatar
ericdwong
Yeah this is a pain in the ***, particularly if the car is older. Once you get it off the first time, you'll see what we mean by the white ring releasing the "fingers". I used a flat head screwdriver and alot of foul language.
Old Jan 18, 2007 | 03:54 PM
Casem1's Avatar
Casem1
I pulled the torque tube and left the slave connected hydraulicly. I just unbolted it from the torque tube. I may disconnect it and maybe not, depends on how the reinstall goes.
BTW, as suspected my pilot bearing is FUBAR.
