Quick header question.....
Old Jan 17, 2007 | 02:44 AM
mike70845's Avatar
mike70845
Default Quick header question.....
How big of a difference hp wise would it make if i went with 7/8 headers over 3/4? Cam and nitrous car....
Old Jan 17, 2007 | 08:41 AM
99 vett babycar's Avatar
99 vett babycar
not very much, doubt if you could feel a difference
Old Jan 17, 2007 | 03:08 PM
mike70845's Avatar
mike70845
so were talking less than a couple hp. any sound difference?
Old Jan 17, 2007 | 03:12 PM
Dan_the_C5_Man's Avatar
Dan_the_C5_Man
You need to consider that you would / could lose HP swapping your 3/4" headers for 7/8".
If you have a stock C.I.D. motor (346), you are going backwards with larger diameter tubes.
Old Jan 17, 2007 | 03:30 PM
99 vett babycar
Old Jan 17, 2007 | 04:05 PM
jeanlucpicard's Avatar
jeanlucpicard
Likewise, when you install 1-3/4" headers and then modify your car to a higher than originally planned level you will find the 1-3/4" primaries will choke the engine back and then you have to replace them with 1-7/8" primaries - like Kooks
The whole thing comes down to a very technical amount of stuff related to ehaust pulses scavenging the cylinders, vacuum pull, back pressure, etc etc. Basically, anything less than 400hp go with the 1-3/4" primaries and anything over 400hp go with the 1-7/8" primaries. The 1-3/4" headers on a stock engine will add about 25-30RWHP and about 30-35 lbft of torque depending on the manufacturer design when combined with an aftermarket exhaust and a dyno tune.
Good luck.
To Quick header question.....
