Tire Pressure Sensor question
Old Jan 19, 2007 | 06:21 PM
TopFuelTim's Avatar
TopFuelTim
Default Tire Pressure Sensor question
Hi all,
I installed four new tire pressure sensors on my car last week (Tom at Fichtner Chevrolet fixed me up), as one of the seven year old ones was beginning to act up, and I was getting two new tires anyway. No problem training the new ones (used directions I found on the forum), and they were all fine until today. I had been on the road about 45 minutes, stopped to drop off a textbook for my daughter at college, and then about ten minutes later, I got a Service Tire Pressure Sensors message (or something like that). My LF sensor reading began showing Lxxx. It stayed this way until I got to work. This afternoon, it was fine.
My question is: Is this normal, or at least expected, behaviour for good tire pressure sensors? If it happens now and then, and is harmless, I'll leave it alone. However, if something is bad, then I will call Tom and ask him about another one.
Thanks,
Tim Glover
Old Jan 19, 2007 | 07:01 PM
Mr. C's 5's Avatar
Mr. C's 5
I've done several sensor installs and never had that happen. Do the re-learn again. If the problem continues it's either a bad sensor or it was not installed correctly and has somehow rotated so that it's touching the rim or was over torqued. Good luck.
Old Jan 19, 2007 | 07:04 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
It is NOT normal. De-pressureize and re-pressureize the tire and check sensor for normalm op. Relearn one more time. If it still acts up, get a new one!
BC
Old Jan 20, 2007 | 11:16 AM
TopFuelTim's Avatar
TopFuelTim
Default Thank you, I'll try it.
I watched the guys install the sensors last week, and everything seemed right as far as the install went. I'll go ahead with the de-pressurize and re-pressurize today and then train the sensors again. Will keep you posted.
Thanks,
Tim Glover
Old Jan 20, 2007 | 12:26 PM
Oldvetter's Avatar
Oldvetter
After I had new tires installed, my one sensor wouldn't work for about 7 miles, until I ran over a railroad track, then it worked. Worked well ever since that. I figured maybe the motion sensor (whatever they use) got stuck.
If yours continue to do this, I'd replace it.
Old Jan 21, 2007 | 12:31 PM
TopFuelTim's Avatar
TopFuelTim
Default Thats what happened with one of my old sensors
Before I put new sensors on, one time my RF display went about three miles with no readout, and then I hit a bump on a new bridge and the seven year old RF sensor started working again. It had also acted up several times before that, so I knew their time was about up.
Tim Glover
Old Feb 3, 2007 | 11:04 AM
TopFuelTim's Avatar
TopFuelTim
Default Thank you Bill Curlee
I de-pressurized, and the re-pressurized the LF tire, and then re-trained the sensors again per your advice from two weeks ago. Have driven it almost every day since then with no more problems.
Thank you,
Tim Glover
Old Feb 3, 2007 | 11:25 AM
69's Avatar
69
Cruise-In VI Veteran
Note, beware when buying new sensors! There is a MFG date on the sensor and mine were made in 1996. Well, I bought one new and it had a MFG date of 1997 and it too craped out with a year of service. I cut it open and found out that the battery in the sensor was DEAD!
Old Feb 3, 2007 | 12:27 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
EXCELLENT INFO!!
BC
Old Feb 7, 2007 | 08:49 PM
texastea10's Avatar
texastea10
8th Gear
Originally Posted by TopFuelTim
Hi all,
Thanks,
Tim Glover
Hi Tim
If you have the Training Instructions could you please send. I am now having this problem. Also hope you resolve yours !!
Thanks in Advance !!
Bill
Last edited by texastea10; Feb 7, 2007 at 08:50 PM. Reason: Wrote Learning instead of Training
Old Feb 7, 2007 | 10:33 PM
TopFuelTim's Avatar
TopFuelTim
Default This should help. Is very easy
I used another thread, but just found this link from another post. Same thing.
Take care,
Tim Glover
http://www.frankhunt.com/FRANK/corve...g_the_TPS.html
To Tire Pressure Sensor question
