Winter Oil Change Question
Old Oct 2, 2001 | 09:20 PM
Greg00Coupe's Avatar
Greg00Coupe
Default Winter Oil Change Question
Here in Ohio unfortunatly the snow and Corvette hibernation is just around the corner. My question is simple... Do I change oil now and let new oil sit in the pan all winter or wait until spring and driving season? I change oil once a year and last year I changed it in the fall.
Opinions welcomed!!!
Old Oct 2, 2001 | 09:25 PM
C6~Missle's Avatar
C6~Missle
Default Re: Winter Oil Change Question (Greg00Coupe)
You want to store it with fresh oil. Get those contaminant and acids out of the engine. You should also flush your brakes if the time is close.. you don't want the moisture in the brake fluid sitting in there all winter.
mike :flag
Old Oct 2, 2001 | 09:32 PM
Nekbyter's Avatar
Nekbyter
Default Re: Winter Oil Change Question (C5~Missle)
1: Doesn't the C5 have the synthetic DOT5 brake fluid (which doesn't absorb moisture like 3 or 4)?
2: After changing oil for winter storage isn't also recommended to do it on a warm engine and then to run the engine for a few minutes to cycle the clean oil to all the bearing surfaces and what-nots so that the old cruddy oil is no longer on those surfaces?
Old Oct 2, 2001 | 09:38 PM
C6~Missle's Avatar
C6~Missle
Default Re: Winter Oil Change Question (Nekbyter)
The C5 uses DOT 3 fluid, it is not synth.
Mike
Old Oct 3, 2001 | 12:12 AM
carpe dm's Avatar
carpe dm
Change it now! Put some Sta-Bil in the gas and run it a few minutes before storage. Extra air in the tires, etc. Hard to put it away....used to mine in Michigan for 5 or 6 months over winter! :(
Old Oct 3, 2001 | 01:32 AM
Rob 99's Avatar
Rob 99
I'm "Apache" a psycho dog
Do like the others said, Sta-bil in the gas full tank to prevent moisture buildup, anfd fresh oil and filter, i would not mess with the brake fluid though it has a long life, i am assuming you have a C-5? youll only be down 4 or 5 months( say, Dec, Jan, Feb, Mar, hopefully back on the road in Apr, hey im iin N.J. so i go through the same stuff as you, and do it with my boat too! Rob.
Old Oct 3, 2001 | 01:53 AM
borba's Avatar
borba
Default Re: Winter Oil Change Question (Rob 99)
All I have to say is Thank god I live in Vegas and I never have to put my car away for the winter. I know this does not help but I love my vette so much I would consider to move somewhere where I can drive 24hrs a day, 7 days a week, and 12 months a year! :flag
Old Oct 3, 2001 | 09:06 AM
chuck1026's Avatar
chuck1026
Cruise-In II Veteran
Default Re: Winter Oil Change Question (borba)
Rob and Carpe have the right idea... definitely store it with fresh oil.
Old Oct 3, 2001 | 11:31 AM
jerryv's Avatar
jerryv
Default Re: Winter Oil Change Question (chuck1026)
Put fresh oil in before winter .. and DON'T STORE YOUR CAR .. drive it! I'm not suggesting you slog it thru the snow, but there are always a few nice days every month when the streets are dry and the sun is out. The car loves the cold weather.
Old Oct 3, 2001 | 01:05 PM
Nekbyter's Avatar
Nekbyter
Default Re: Winter Oil Change Question (Jerry Velders)
Yes there are a few nice days during winter months here in the great white north and you could take the vette out. However it should be a long enough run to burn off the moisture and condensation that is caused when you start a cold engine. Anyone who goes out to the garage and starts their car up once a week and lets it run for 10 minutes is doing more harm than good. I heard that it takes 45-60 minutes to burn off all the moisture that can be trapped inside.
To Winter Oil Change Question
