Heads?
Old Jan 20, 2007 | 02:06 AM
Sheenadianah's Avatar
Sheenadianah
Default Heads?
I have an 04' with quite a few mods and wanted to put heads on for some added horses but haven't decided on the brand. Any ideas?
Old Jan 20, 2007 | 03:58 AM
Blown 346's Avatar
Blown 346
Qtp,afr.
Old Jan 20, 2007 | 08:27 AM
qwkz06's Avatar
qwkz06
AFR....do a search.
Old Jan 20, 2007 | 09:49 AM
Irish Whiskey's Avatar
Irish Whiskey
if cost is an issue check out Patriot or Livernois -243(LS6) heads will give good power.
Old Jan 22, 2007 | 12:14 PM
Dave@LivernoisDSS's Avatar
0Dave@LivernoisDSS
Former Vendor
Our heads are a little on the conservative side, number wise that is.
Old Jan 22, 2007 | 12:36 PM
miami993c297's Avatar
miami993c297
Did you made a search with the words ETP Heads ??
Like mine :
Christian
Old Jan 22, 2007 | 02:39 PM
Dave00C5's Avatar
Dave00C5
Afr's are probably the best but also the most costly. ETP are right there too if you can get em.
Old Jan 23, 2007 | 12:03 AM
spiral04's Avatar
spiral04
Lately I've seen Trick flows getting good numbers.
Old Jan 23, 2007 | 04:55 AM
LKGRenegade22's Avatar
LKGRenegade22
It really depends if you are looking to get a good set of budget heads or go all out. Let us know what you are looking to spend and you should have some much more informative replies.
Old Jan 23, 2007 | 09:18 AM
Irish Whiskey
AFR's will handle the full radical mods better than anyone. However, they are probably overkill for a mild head/cam combo (220's,lsa around 114) that will be a daily driver first and then a track car. If I was going into the 240's, lsa 108 or 110 with a big shot of nitrous then I would go to AFR. Also I would give them serious thought if I was going the big power twin turbo route.
Patriot can and I'm sure Livernois can as well get you to 300cfm at .600 with a set of heads -talk to Rick at Livernois about his cam set up.
To Heads?
