Got Vararm...Need Filter. Ideas???
I purchased the VR-B2 system when it was relatively new on the market and still being shipped with the foam filters. If anyone knows a a better filter being produced for the system I'd be very grateful of the information. I've checked the VR website and discovered the've switched to the greefilter filters. I know nothing about them so I'm leary about ordering.
All help is greatly appreciated.
Thank you.
K & N filter for Vararam Industries VR-B2 C5 Corvette
Vararam #KN332522B1B2 $69.95 Jan 2007
K&N # 33-2522
Product Specifications
Product Style: Panel Air Filter
Height: 0.688 in (17 mm)
Outside Length: 16.75 in (425 mm)
Outside Width: 5.313 in (135 mm)
Filter Re-Oiling Amount: 0.7 oz (21 ml)
Inner Wire: No
Top Style: Open
Weight: 0.9 lb (0.4 kg)
Product Box Length: 17.13 in (435 mm)
Product Box Width: 8.25 in (210 mm)
Product Box Height: 1.75 in (44 mm)
AC A1337C
TRIUMPH C29986
TRIUMPH C30489
WIX 46005
Fits
1975 - 1982 TRIUMPH TR-7 - 2000
Best E-bay $47.00
Update try this for the differences http://www.vararam.com/b2.html
The KN 25-3322 (fits TR-7) needs to have the corners cut (reduce the radius) to fit within the housing. You also have to make a "gasket" as the KN is much thinner than the old Foam filter. I actually epoxied the KN into the housing and disassembled the foam filter and used the outside as the gasket. Worked very well....
K&N # 33-2522
Inner Wire: No
Top Style: Open
AC A1337C
TRIUMPH C29986
TRIUMPH C30489
WIX 46005
Fits
Best E-bay $47.00
I think as it says, "The B2 system for the C-5 Corvette has evolved several times over the years for added performance and ease of filter maintenance."
Per Vararam, the green filter doesn`t fit the EARLIER B2`s properly (later B2 lids have deeper edging/flanges), for the earlier B2`s they offer an K&N type filter along with weather striping as a KIT, for the retro-fit.
On later B2`s the lid is properly designed for the GREEN Filter as noted above and does not require weather stripping or trimming, etc.
I recommend calling Vararam tech dept to verify which specific version you have so that you can order the proper filter.
RickP.S. And yes, I know this because I recently ordered a KIT for my earlier B2 directly from Vararam.
When I went to the K&N, Vararam was just releasing the Green Filter. I e-mailed and responded to a thread they supported awhile back, but never got a response. So I went and developed one myself around the K&N filter. seems to work pretty good.
Either Vararam gauze filter should fit well, but you'll need trimming instructions if you purchase the green one.
From Vararam:
"The new VR-B2 unit is the third generation of our record setting VR-B2 system."
I wonder which one I have !!??!!
