Question: Battery charging while in car
Old Jan 21, 2007 | 01:07 AM
50th in the 49th's Avatar
50th in the 49th
Default Question: Battery charging while in car
I am storing the Vette in my heated garage for the winter. I bought a CTEK charger for the battery (which is a GM AGM battery). I was planning to leave the battery in the car, but was wondering if gas ventilation would be an issue with the hood shut and a cover on the car. I planned on routing the charger wires around the gasket so the hood would shut OK, but I'm worried about gas building up in the battery compartment if I do it this way. Any thoughts?
Old Jan 21, 2007 | 07:06 AM
foremaw's Avatar
foremaw
Active Streak: 90 Days
St. Jude Donor '08-'09-'10-'11-'12
I've never had a problem and I don't believe you need to worry about it. I don't close the hood, its just resting on the latches. The hood light is out. I cover with a breathable indoor car cover.
Old Jan 21, 2007 | 07:16 AM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
Yep.. plus, a good charger will not gas a battery as it will cut off when the battery is fully charged.
Old Jan 21, 2007 | 03:04 PM
50th in the 49th
Thanks. I've got a CTEK 3300, but the manual still cautions about gassing and ensuring adequate ventilation.
Old Jan 21, 2007 | 03:23 PM
Funn One's Avatar
Funn One
Thats what i do!!!
Old Jan 21, 2007 | 08:19 PM
50th in the 49th
Originally Posted by Funn One
Thats what i do!!!
Guess I'll see how it goes.
Old Jan 21, 2007 | 11:38 PM
ALLEGRO's Avatar
ALLEGRO
You should not get any gassing with a "smart" charger. The claim to need ventilation and such is probably just overkill to avoid legal action if one loses its mind and overcharges.
Buy a good tender and check for heat from time to time. Afterall, you surely pull the cover off from time to time just to take a look.....don't you?
Old Jan 21, 2007 | 11:51 PM
50th in the 49th
Oh yeah Have to make sure that the color didn't change
Old Jan 22, 2007 | 03:23 PM
Dave68's Avatar
Dave68
good idea!
Old Jan 22, 2007 | 04:51 PM
Bill Dearborn's Avatar
Bill Dearborn
Even if gassing occurs it is not a problem as long as there is no spark. Before doing anything with the charger just open the hood and the hydrogen gas will rise (it is lighter than air). In the larger volume of your garage the hydrogen percentage will not be high enough to support combustion. Once the hood has been open for a minute or so you can safely do something with the car.
Bill
Old Jan 22, 2007 | 05:02 PM
You shouldn't have any problems - I've kept my battery connected to a Battery Tender and the car covered for a number of years with no adverse effects.
To Question: Battery charging while in car
