Headlamp Shroud Access Caps
Old Jan 21, 2007 | 07:30 PM
Burgie's Avatar
Burgie
Default Headlamp Shroud Access Caps
Does anyone have a simple fix-aside from glue-to keep the access caps from blowing off on the pop-up headlamp shrouds? I had to replace the entire shroud and cap on the left and now the right is missing. If anyone has a spare cap send me a email on cost.
Old Jan 21, 2007 | 07:40 PM
hotwheels57's Avatar
hotwheels57
I'm not sure what the OD is on the oem headlight plugs, but any ACE or TRUE VALUE hardware stores have a good selection of "hole plugs" in hard plastic, vinyl or metal with tangs...might be an option. You can find them in the same area as the regular fasteners (bolts/nut/screws etc).
Old Jan 21, 2007 | 07:59 PM
Burgie's Avatar
Burgie
Thanks, never even thought to check there-first thought is the Stealership-
Thanks again
Old Jan 21, 2007 | 09:12 PM
MAC5's Avatar
MAC5
Burgie, measure the opening if its the 2 1/8 inch plug, might be able to help you out.
Best bet is to silicone seal those plugs on from the inside. I haven't lost any since late 98.
Blown 346's Avatar
Blown 346
Mine ended up taking a flying lesson and vanished. I was able to replace mine for $5 thru the dealer. They new one fit really snug.
Old Jan 21, 2007 | 10:49 PM
Burgie's Avatar
Burgie
1 & 1/8" it is- do you have one and how much?
email me for further-thx
Old Jan 22, 2007 | 08:59 AM
vetdude's Avatar
vetdude
Here's the best solution: Pick up a new pair of the "later model headlight bezels" with the locking plugs from Fred Beans Chevrolet (supporting vendor - ask for Dave). Less than $30 shipped - problem solved. The original plugs were made too small for the openings on the older bezels, thus the popping out problem. GM finally realized there was a problem and corrected it with the "locking plugs." SNAFU.
Old Jan 22, 2007 | 01:06 PM
bighank's Avatar
bighank
Default caplugs
Go to CAPLUGS in upstate NY on the Internet. They will send u a FREE SAMPLE of the plug you need if you have the OLD STYLE plug, just a round CAPLUG without the locking tab. Can't remember the size but I think its 2 1/4" but CHECK IT OUT before ordering a sample. Then USE SOME BLACK RTV to KEEP IT IN THERE. When adjusting the headlights take out the 3 screws and remove the whole plastic shroud capplug and all. I have ONE old style and one NEW style and they both have the "removable" PLUG RTVed in place. BIGHANK
Old Jan 22, 2007 | 05:14 PM
Had that problem on my '99- dealer ended up getting the revised bezel and plug that locks in place and never had another one blow off.
Old Jan 22, 2007 | 05:25 PM
ericdwong's Avatar
ericdwong
Here's a solution, I just left the plugs off and said screw it.
Old Jan 22, 2007 | 06:05 PM
TEXASCOUPE's Avatar
TEXASCOUPE
I ran a small bead of RTV silicone around it and put it back on. Better than glue, will still be able to get it off if needed. With glue maybe not.
Old Jan 30, 2007 | 09:03 PM
95BLKVette's Avatar
95BLKVette
Thanks, BTW, its the 2-1/8" size
Old Jan 31, 2007 | 12:28 PM
hotwheels57
That probably larger OD than anything you'll find in the hardware store "hole plug" section. RED GREEN would suggest duct tape.
Old Feb 1, 2007 | 12:55 AM
Yello95's Avatar
Yello95
St. Jude Donor '11
I think you meant 2 & 1/8", right? Did you ever get a plug? email me your mailing address if not and I will send you one
usacorvetter@att.net
Old Feb 1, 2007 | 12:58 AM
Yello95's Avatar
Yello95
St. Jude Donor '11
...and when the light is up and on ...from the side it looks like a spotlight
Old Feb 1, 2007 | 08:40 AM
MAC5's Avatar
MAC5
I sent Burgie one last week, he received it over the weekend. Silicone, silicone those things and they won't go away.
Old Feb 1, 2007 | 06:38 PM
Yello95's Avatar
Yello95
St. Jude Donor '11
Excellent...anyone else need a plug, let me know
To Headlamp Shroud Access Caps
