Ti z06 exhaust question
Old Jan 22, 2007 | 05:14 PM
Mongolink's Avatar
Mongolink
Default Ti z06 exhaust question
Are the exhaust manifold and h pipe the same on a ls1 vs a z06 ???
Thanks for your help
Tom
Old Jan 22, 2007 | 06:18 PM
The Wrench's Avatar
The Wrench
Well, yes and no, depending on year.
I did a lot of research when I converted my 2000, and here is what I think to be true.
'97-'99 used a short H-pipe, which won't match with the later manifolds. They used a longer stainless steel manifold.
AIR pipes attached to #8 cylinder, and oil dipstick attached to #6.
2000 models used the new longer H-pipe (most had 2 converters, but West Coast & some East Coast had 4 converters).
These also used a stainless steel manifold, but shorter (only used in 2000).
AIR pipes still attached to #8 cylinder, and oil dipstick attached to #6.
01-04 used the longer H-pipe, but the LS1 had 4 converters, and the Z had only two converters.
All 01-04 used the new cast manifolds (short). LS1 and Z06 were identical.
AIR pipes moved to #6 cylinder, and oil dipstick attached to #4.
So, it's a hodge-podge, with the 2000 (I own one) being the bastard child changeover model. (some say the later 2000's converted early to the '01 setup - I can't comment on that).
Summary. all '01-'04 LS1 and Z06 can exchange manifolds and H-pipes at will. Only dif is the lS1 H-pipe has the two extra little "pup" cats
and the Z does not.
For the older cars, you have to mix and match as indicated above.
To upgrade a '99 to Z parts would require any '01-'04 manifolds, a Z06 H-pipe, and also any '01-'04 AIR pipe and oil dipstick.
Good news - all catbacks (mufflers) interchange on all years.
Whew,
DG
Old Jan 23, 2007 | 11:14 PM
Mongolink's Avatar
Mongolink
Default You da man !!!
Thanks for all that I fired of a pm to you also
Thanks again
Old Jan 24, 2007 | 02:22 AM
Dan_the_C5_Man's Avatar
Dan_the_C5_Man
A slight clarification; not all late-model LS1 H-pipes had pup cats, and the cats on the Z06 (2002+ for sure) are different than the Coupe (slightly higher-flow, claimed by GM to be worth about 5 HP).
Old Jan 24, 2007 | 07:59 AM
Mongolink's Avatar
Mongolink
So would my stock 2000 h pipe and the 2002 zo6 h pipe be able to be swapped ?
Are they the same dimension in overall lengh ??
Old Jan 24, 2007 | 09:02 AM
VetteDrmr's Avatar
VetteDrmr
Mongo,
FYI, the Z06 h-pipe and the C5 h-pipes are made out of the same material (IOW, the Z06 h-pipe is *not* Ti). I'm assuming from the title of your question that you're considering getting a set of Ti exhausts to replace your stock mufflers. If that's the case, they bolt right up, for all model years, AFAIK.
HTH, and have a good one,
Mike
Old Jan 24, 2007 | 11:51 AM
Mongolink's Avatar
Mongolink
Yes, I have the entire system, from the manifolds back, I was wondering if I would gain anything by using the h pipe off the z06 or just use the stock h pipe on my 2000.
Thanks again to all who help this forum thrive !!!
Tom
Old Jan 24, 2007 | 01:06 PM
Cobra4B's Avatar
Cobra4B
CI 3-5-6-7-8 Veteran
The only Ti part is the '01-'04 Z06 catback. I wouldn't waste my time w/ manifolds and different H-pipes... just get a LT header system w/ cats and an x-pipe.
Old Jan 24, 2007 | 01:58 PM
VetteDrmr's Avatar
VetteDrmr
Tom
Tom,
You'll get anywhere from zero to "nothing worth measuring" by upgrading to stock Z06 manifolds and h-pipe.
The Ti exhaust is an excellent upgrade, though.
Have a good one,
Mike
Old Jan 24, 2007 | 04:20 PM
Mongolink's Avatar
Mongolink
Default Done deal!!!
Thanks for the assistance all !! TI'S it is. you all just saved me alot of aggravation foolin with all that other stuff... at least till I can spring for the lt headers and xpipe !!
Old Jan 24, 2007 | 05:40 PM
VetteDrmr's Avatar
VetteDrmr
To Ti z06 exhaust question
